Its latest effort is the HCCI internal combustion engine, a spark-ignition piston engine that can operate as a compression ignition motor, similar to a diesel. GM installed a version of the engine in both a
Saturn Aura and an Opel Vectra and let us drive them around its proving grounds in Milford, Michigan.
General Motors says HCCI (Homogeneous Charge Compression Ignition) can yield a 15 percent improvement in fuel economy. But there are a few caveats. First, GM Powertrain Chief Tom Stephens says the technology won't likely reach production before 2015. And second, this impressive number includes the cumulative efficiency of variable valve timing and lift as well as direct injection, both of which must be in place for compression ignition to operate.
Compression ignition is all about the temperature inside the combustion chamber. In compression-ignition mode, the exhaust valves close earlier, trapping some of the heated air from the previous combustion cycle. This warms the incoming fuel mixture sufficiently to produce ignition once it's compressed by the piston. Clever stuff. But when the engine is under load — while accelerating, for example — the engine must transition back into spark mode to make full power.
