Results 1 to 19 of 19
    Dec 2003
    mga tsikot peep...currious lang po ako bagito lang kasi ako pagdating po sa turbo injected na engine..ano po ba magandang turbo na meron sa market ngayon?at kung magkano po...
    si bossing AutoXer ang kausapin mo diyan... hehe
    yup! you can email him at auto_xer*yahoo.com
    bihira sya magpost sa boards eh.
    for what car? Jap or Euro car? for Japs - meron HKS Kits. For Eurocars-marami rin choices. Meron din generic like Garret turbo tapos mag-custom build ka na lang ng pipings,intercooler, and bili ka na lang ng generic na fuel pressure regulator or engine management ecu. Sila Ferman a.k.a. autoxer of Fusion R kaya yan.
    turbo kits and installation range from a low of Php 70thousand to a high of Php 200thousand depending on the brand and level of accompanying parts (ecu/engine management, intercooler, etc...). As far as I know, at least 40hp to as high as 60hp ang dagdag na power.
    btw, if you have a euro car, i can probably help you to avoid some common pitfalls. i recently installed a mosselman turbo charger with intercooler in my E36 320i. sila ferman ang nag-tune but it was autoplus who installed it. the dyno shows 50hp ang dagdag na power to the wheels. PM me if you want more info.
    nasa fusionR na si ferman(autoexer)?, sila oliver pa ba yung me-ari nun o hindi na?.
    1.8T::: Kasosyo si boss Ferman dun and yes boss Oliver is still there (with occassional trips all over the globe to search for interesting parts )
    ahh.
    ayos ah.
    Dec 2003
    Woodfire tnx sa info Jap car ride ko..toyota exsior (4S-FE)2cc all stock lang sya....isa pang tanong at what rate ng RPM naman kaya papalo ang turbo? maganda bang maglagay ng turbo pag d laging straightline ang tinatahak mong road lets say lagi ka sa baguio?
    Nov 2003
    the newer turbos have been built to minimize lag.
    and you can get turbo customized for your application.
    uy, okay gawing project car yan!!!
    maraming choices sa turbo and you can customize the tuning depending on how you will use it. yung mosselman na kinabit ko sa E36, 2000+ rpm pa lang sumisipa na yung turbo. very minimal ang lag kasi relatively small ang kinabit kong turbo. ang priority ko is the torque improvement kasi mabigat ang body ng E36.
    before you install a turbo, pa-compression test mo muna yung engine mo so you will know if your engine is in good condition and turbo ready.
    if it is in good condition, check out various options. you can go to Fusion R c/o Ferman or Oli. You can also check out Autoplus along EDSA and look for Raymund. compare prices and the cost of the collateral parts such as engine management system, fuel pressure regulator, intercooler, piping, etc...
    if you have the budget, pa-dyno mo yung car before & after turbo installation so you will know exactly the increase in hp to the wheels. good luck with your project.
    my 2001 jetta 1.8T still has the stock ko3 sports turbo, kinda small so it starts pulling at low 2000rpm, chip, exhaust, turbo h valve gets me spiking 20-21 psi and holds 12-13psi at 7k red line.
    a big jump from stock 7-8psi(150hp) to over 200hp and 255 torque.
    good luck on your project and pasakay pag uwi ko dyan next year.
    ah...the mighty 1.8 vw turbo - i raced an MT audi a4 turbo a few weeks ago with chip/exhaust/bov/other stuff in my (automatic) 330ci and LOST!! :mad: grrr.....
    M54, did you race with the same set-up with your opponent?
    no, my car is stock with automatic (steptronic) transmission. i even forgot to put the stupid thing in sport mode.
    he had (from what i can see) a manual tranny, exhaust, and a blow-off valve (could hear it when he shifted). i asked him later on and he said he was chipped to 13 psi with the stock turbo.
    Dec 2003
    pwede po bang malaman ang mga locations at Contact # or even email ng mga peeps above proprietors....need few advices on modification libre poba ang assesment hehe....tnx po..ganda pa responce ang ang ride ko kelangan lang ng konting boost siguro lalo sa Nlex ..low rev lang d gaya ng mga honda na high revs on stright line ..
    FusionR landline: 724-3921 look for Ferman Lao or Oliver
    Autoplus - along Edsa just before PGA Cars if you're going to Mkti. look for Raymund.
    audi a4 turbo?, stock turbo yata nun eh ko4, slight bigger impellar.
    I raced a subaru wrx with exhaust and lost half a car, but I pulled first and 2nd, dulas sa third gear.
    someone is selling a Toyota TD12 OEM turbo with an intercooler at Freemuff in San Juan for P9000. Do note that the turbo is kinda small, so best for 1.3 engines.
Turbo
