Results 11 to 19 of 19
December 14th, 2003 05:01 PM #11Originally posted by Duke
Woodfire tnx sa info Jap car ride ko..toyota exsior (4S-FE)2cc all stock lang sya....isa pang tanong at what rate ng RPM naman kaya papalo ang turbo? maganda bang maglagay ng turbo pag d laging straightline ang tinatahak mong road lets say lagi ka sa baguio?
maraming choices sa turbo and you can customize the tuning depending on how you will use it. yung mosselman na kinabit ko sa E36, 2000+ rpm pa lang sumisipa na yung turbo. very minimal ang lag kasi relatively small ang kinabit kong turbo. ang priority ko is the torque improvement kasi mabigat ang body ng E36.
before you install a turbo, pa-compression test mo muna yung engine mo so you will know if your engine is in good condition and turbo ready.
if it is in good condition, check out various options. you can go to Fusion R c/o Ferman or Oli. You can also check out Autoplus along EDSA and look for Raymund. compare prices and the cost of the collateral parts such as engine management system, fuel pressure regulator, intercooler, piping, etc...
if you have the budget, pa-dyno mo yung car before & after turbo installation so you will know exactly the increase in hp to the wheels. good luck with your project.
- 166
December 15th, 2003 12:37 PM #12my 2001 jetta 1.8T still has the stock ko3 sports turbo, kinda small so it starts pulling at low 2000rpm, chip, exhaust, turbo h valve gets me spiking 20-21 psi and holds 12-13psi at 7k red line.
a big jump from stock 7-8psi(150hp) to over 200hp and 255 torque.
good luck on your project and pasakay pag uwi ko dyan next year.
December 15th, 2003 02:27 PM #13Originally posted by 1.8T
December 15th, 2003 03:51 PM #14Originally posted by M54 Powered
ah...the mighty 1.8 vw turbo - i raced an MT audi a4 turbo a few weeks ago with chip/exhaust/bov/other stuff in my (automatic) 330ci and LOST!! :mad: grrr.....
December 15th, 2003 11:54 PM #15Originally posted by 20vanda01
M54, did you race with the same set-up with your opponent?
he had (from what i can see) a manual tranny, exhaust, and a blow-off valve (could hear it when he shifted). i asked him later on and he said he was chipped to 13 psi with the stock turbo.
- Dec 2003
- 35
December 16th, 2003 02:37 AM #16pwede po bang malaman ang mga locations at Contact # or even email ng mga peeps above proprietors....need few advices on modification libre poba ang assesment hehe....tnx po..ganda pa responce ang ang ride ko kelangan lang ng konting boost siguro lalo sa Nlex ..low rev lang d gaya ng mga honda na high revs on stright line ..
December 16th, 2003 07:26 AM #17
FusionR landline: 724-3921 look for Ferman Lao or Oliver
Autoplus - along Edsa just before PGA Cars if you're going to Mkti. look for Raymund.
- 166
December 16th, 2003 03:01 PM #18audi a4 turbo?, stock turbo yata nun eh ko4, slight bigger impellar.
I raced a subaru wrx with exhaust and lost half a car, but I pulled first and 2nd, dulas sa third gear.
December 16th, 2003 07:46 PM #19
someone is selling a Toyota TD12 OEM turbo with an intercooler at Freemuff in San Juan for P9000. Do note that the turbo is kinda small, so best for 1.3 engines.
Planning to buy a second car. Help me choose. Honda accord has 71k mileage for ₱465,000 Nissan...
honda accord 2014 2.4L vs nissan altima 2015
