Results 1 to 2 of 2
April 25th, 2009 02:23 PM #1
Tips naman ang proper way ng pag overtaking sa manual . Sabi kasi ng iba ay downshift lagi ginagawa pero sakin laging pressdown lagi ang gas lalo na pag sa 3rd or 4th gear ako.
Tips na din kung paano mag drive ng car with turbo.
Hindi ko pa kasi na try mag drive na kotse na merong turbo.
April 25th, 2009 02:36 PM #2
driving turbo cars: drive it as a normal car, just let it idle for a few seconds before patayin makina lalo na after a hard drive.
power ng cars w/ turbo usually nasa 2500rpm, depende sa specs ng makina.
in overtaking--the common thing is pakiramdaman mo sasakyan mo--kaya ba?pero may method yan-- dapat alam mo specs ng sasakyan mo--kelan maatain ng engine max power and maximum torque. usually, modern gas engines power starts at 4500, where usually maximum torque lies. sa diesel, usually as low as 1,800 rpm lang max torque na.
ako maxima, 2.0gas, i overtake in 4th gear kung may momentum--kayang kaya.. smaller displacemet engines most of the time needs to downshift because of having a smaller torque...
pero usually, 3rd gear talaga, where usually 1:1 ang gear ratio at power can be easily be tapped.
and please, again-----OVERTAKE ATLEAST 15KPH MORE THAN THE VEHICLE YOU ARE OVERTAKING! otherwise, let us pass!
i suppose, it's ok for empty nest syndrome owners who do not drive to farther-flung areas. ......
VinFast VF 3
