Results 1 to 5 of 5
May 2nd, 2008 07:19 PM #2
in my case sir, i prefer to drain all fluids every 40k or four years (which ever comes first). mas ok pa din preventive kesa corrective.
May 2nd, 2008 08:02 PM #4
sabi po nila naninigas yung coolant sa engine block kaya mas ok siguro drain lahat? ano po ba yung coolant na gamit nyo?
Tsikot Member Rank 4
- Jun 2006
- 2,605
May 2nd, 2008 08:14 PM #5Answer depends on your coolant and engine manufacturer.
Green coolant or ethyl glycol 2 years life. Common brands are prestone, total, whiz etc...
Dexcool or orange coolant is supposed to be 5 years or 100,000 kms. Personally, I'll still change every 2 years. Normally found on GM cars. Caltex is the manufacturer. Ford prohibits the use of this coolant on their engines.
Toyota uses red coolant. I forgot idf its HOAT or OAT. Also forgot the reccomended change interval. Parang 2 years din but I may be wrong.
No idea on Honda, Mitsu, German and Korean cars.
Bottom line check your manual.
At the expense of rear cargo space. The floor is raised around 8inches for the batteries.
2021 Toyota Land Cruiser LC300
