Results 1 to 5 of 5
May 2nd, 2008 07:19 PM #2
in my case sir, i prefer to drain all fluids every 40k or four years (which ever comes first). mas ok pa din preventive kesa corrective.
May 2nd, 2008 08:02 PM #4
sabi po nila naninigas yung coolant sa engine block kaya mas ok siguro drain lahat? ano po ba yung coolant na gamit nyo?
Tsikot Member Rank 4
- Jun 2006
- 2,605
May 2nd, 2008 08:14 PM #5Answer depends on your coolant and engine manufacturer.
Green coolant or ethyl glycol 2 years life. Common brands are prestone, total, whiz etc...
Dexcool or orange coolant is supposed to be 5 years or 100,000 kms. Personally, I'll still change every 2 years. Normally found on GM cars. Caltex is the manufacturer. Ford prohibits the use of this coolant on their engines.
Toyota uses red coolant. I forgot idf its HOAT or OAT. Also forgot the reccomended change interval. Parang 2 years din but I may be wrong.
No idea on Honda, Mitsu, German and Korean cars.
Bottom line check your manual.
At the 60-80 range the Seal's ICE would be taking over the propulsion duties from the electric...
(11th Gen) Honda Civic
