Results 1 to 6 of 6
    Since tag-ulan, at least magiging mas moisture sa loob ng car compared kung tag-araw, so advisable ba na maglagay ng dessicant or silica gel sa loob ng car? Or any other item that absorbs moisture inside the car?
    try mo uling!
    pangtanggal din ng mga unwanted scents/odors
    if you can get your hands on a huge pack of silica dessicant all the better. good absorber of moisture yun....
    ...naka-denggoy ako dati ng napakalaking pack from the packaging of a router. laki! 8O solve na solve sana sa kotse.... kaya lang i misplaced at hindi ko maalala kung saan ko nalagay :roll:
    Baka kailangan mo na isang baldend desiccant para ma absorbe niya yung moisture at pag katapos nita tapon na yung dessicant mo. Mahal yan desccant!!
    Kung naka park sa bahay mo yung sasayan mo at meron kang dehumidifier e mas magandang gamitin ito.
    ang descicant sir mag-release din nun na-absorb nya na moisture pag na-expose sa air na mas mababa ang dew point kesa dun sa saturation level ng descicant. so pag andar ng aircon release ulit nya yung moisture sa air kasi lower na yung humidity ng cooler air.
    yan po ang principle of operation ng regenerative air dryer. first absorb ng descicant ang moisture from air at high pressure, then reverse flow (at lower pressure) release ulit ng descicant yun moisture kasi lower ang RH sa lower pressure (or temperature for that matter). so pag na release na yun moisture pwede na sya ulit mag-dry ng compressed air.
    there is a product called "Thirsty Hippo" and comes in a pink and translucent container. its pretty effective in absorbing and storing the moisture in the air. I used it before in my previous car when flood water entered the rear floor pan.
Dessicant or Silica Gel Inside Your Car
