Results 1 to 7 of 7
- Jan 2004
- 13
January 21st, 2004 11:17 AM #1Anu-ano yong pagkakaiba ng mga ito (in terms of engine, valves, features / accessories, etc)?
Corolla (89 ba? ++)
Corolla (93?++ models) -- XL / XE / GLi
Lancer (93?++ models) -- EL / EX / GLi / GLXi
Sentra (Series 2) -- may mga models din ba to?
Sentra (Series 3) -- (EX, SuperSaloon)? may mga models din ba to?
Sentra LEC -- models?
Salamat.
January 21st, 2004 12:33 PM #2
Yung 1989 na Corolla may 1.3 at 1.6 engine. 2E yata yung 1.3. Hindi ko alam engine code nung 1.6 pero carb sila pareho.
Lancer is powered by either a 1.3 (EL), 1.5 4g15 in the GLi, and 1.6 4g92 (?) in the GLXi. EX models are basically the same as EL pero released ang mga ito alongside the newer 'pizza pie' lancers of 1997.
Sentra II (a.k.a. B13 platform) ay available in base, 1.5 GSX, and 1.6 models (nissanbayan peeps, please confirm). Ang top of the line models ay yung yellow ang front clearance lamp, walang fender signal at nasa extreme edges ng taillamp ang signal lamp.
Sentra III (a.k.a. B14 platform) available in JX, EX, Spirit, LEC, SS as well as other limited models like the Super Touring and GTS. May 1.4 and 1.6 (ga16) engines. I forgot the other engines in the range.
January 21st, 2004 07:53 PM #3
corolla 1989-1992 aka ae92
variants: xl, xe, gl
xl - 2e engine , no ps(bare model)
xe - 2e engine, ps
gl - 4afe engine, ps , power windows
2e-12 valve carb engine
4afe - 16 valve efi engine
corolla 1993 ++ aka ae100
variants: xl,xe,gli
**almost the same specs as the ae92 except for the different body shell****
lancer models: (el,ex,gli,glxi)
i think these models where available from the year 1993-1997 except for the ex model which as otep said was reintroduced along with the newer "pizza" lancer
el - 1.3 4g13 engine, bare model
ex- same specs as el
gli - 1.5 4g15 engine , ps
glxi - 1.6 4g92 engine, all power
4g13 - 1.3 12 valve carb engine
4g15 - 1.5 12 valve efi engine
4g92 - 1.6 16 valve efi engine
i think the b13 platform was the sentra 1, coz as far as i can remember the sentra2 is dubbed as the lec body and the sentra 3 is known as the "super touring" body. (not sure about that)
sentra 1
1.5 sgx(?)
1.6 sgx
sentra 2
1.3 lec
1.4 jx
1.6 super saloon
1.6 super saloon se
sentra 3
1.4 se saloon
1.6 super saloon
1.6 super saloon se
1.6 gts
1.6 exalta
(the gts and the exalta was a facelifted version of the series 3 body)
sentra 4
1.3 gx
1.5 ds
1.6 grandeur
(this is the latest model of the sentra that u can see in the showrooms)
January 22nd, 2004 02:09 AM #4
Regarding the Sentra
Sentra series 1 (1988-1991)
chassis code: B12
engine displacement 1.6 1.5 1.4 and diesel
nickname: boxtype sentra
noteworthy: powersteering
Sentra series 2 (1992 - 1995)
chassis code: b13
engine displacement: 1.6 1.4 1.3
variants: Super Saloon, LEC, SE Saloon, Super Touring
top-of-line engine type: 1.6 liter GA16DE (110hp)
noteworthy: independent suspension, ABS (1993), all power options, fuel injection, variable engine ignition timing
nickname: series 2, LEC-type, ECCS
Sentra series 3 (1996-1999)
chassis code: b14
variant: super saloon, LEC, SE Saloon, GTS, Exalta
top-of-line engine type: 1.6 liter GA16DNE (105hp) later GA16DE (110hp)
noteworthy: rear beam suspension, power folding side mirrors, sunroof available on certain models.
Sentra series 4 (2000-current)
chassis code: b15
engine displacement: 1.6 etc
variant: grandeur, etc
noteworthy: brand new efi engine, new chassis
January 22nd, 2004 11:10 AM #7
add'l info:
regarding sentra:
series 3:
1.4 ex saloon pala yun lower variant
1.6 super saloon yung middle variant (all power)
1.6 super saloon se yung top of the line . + 4 wheel discs /abs
1.3 fe - a bare model introduced in the year 2k -2k1
series4:
1.3 gx - bare model but still using the b15 body shell ;
1.5 ds - middle variant
1.6 gs superio \
1.6 grandeur / not sure whos the top of the line variant
between the two. i just saw both cars in c5 but with different model trim.
btw noteworthy of the sentra 4/b15 is the new QG engine. which is equivalent to the award winning VQ engine used in the cefiro.
have you tried spraying peppermint?
How to get rid of kittens in the engine bay
