Results 1 to 7 of 7
    Found this article and would like to share it here at tsikot:
    Driving in the city is a sport unto itself. Clogged expressways, impossible parking, countless red lights, never-ending construction, and the constant threat of car theft can make a trip downtown more than frustrating — it can turn the most mild-mannered Dr. Jekyll into a shouting, swearing Mr. Hyde. (And you know what I'm talking about.)
    There's a lot you can do, though, to make urban driving easier, both when choosing a car and while out on the road. Here are some tips that will make nasty drives into the city less stressful and more enjoyable.
    1) Get a car that fits: Whether you find street parking (when you're running late, of course) is often a direct function of your car's size. Even the paid parking lots seem to have spaces only for "compact" cars. If you do a lot of city driving, having a smaller car — in width as well as length — will not only make parking easier but will help prevent dings, dents and scrapes.
    2) Think carefully about manual vs. automatic: Manual-transmission cars are fun, less expensive and often more fuel-efficient, but driving them in stop-and-go traffic can make driving stressful and tiring, particularly in hilly cities like San Francisco. So weigh the trade-offs between the two transmissions if you know you'll be in town frequently.
    3) Do the mpg math. City drivers inevitably get worse fuel mileage, hence the distinction between "city" and "highway" mpg estimates on the window sticker. When you think about buying a car, combine the sky-high cost of fuel with the manufacturer's lowest mpg numbers, and you'll have some idea what to expect at the filling station.
    4) Look for parking assist technology. No one likes the sound of a truck in reverse ("beep, beep, beep"), but the electronic chime of parking assist will help you squeeze into small spaces with less trouble. (It may also prevent you from running into a person or object behind you.) Rear parking sensors are fairly common, and some luxury cars offer them in the front as well.
    5) Drive with mileage in mind. Don't speed up just to slow down. If you lean on the accelerator when the light turns green, then again on the brake one street down, you're hurting both your car and your gas mileage. Instead, go lightly on the accelerator and coast where possible. If you're bumper-to-bumper, improve your fuel economy by slipping the car into neutral instead of constantly riding the brake. (This doesn't apply to hybrids which typically shut off the gas engine when stopped in traffic.) And don't try to get around the city on less than a quarter tank. Not only are city gas stations expensive, they're hard to find.
    my personal favorite
    6) Pick a lane and stick to it. Believe it or not, changing lanes frequently will get you there only a few seconds earlier, while greatly increasing your chance of a collision.
    7) Replace your air filter often. City driving means smog and soot. Your air filter protects you and your occupants from breathing the worst of the fumes and the particulates they carry. By the time some stranger has written "Wash Me" on your rear windshield, it's already too late for your lungs.
    8) Make your car crime-resistant. Take it from an ex-Manhattanite: You can't be too careful. Try to park in an area that's well lit and has a lot of pedestrians nearby. Don't leave valuables — including gym or shopping bags — visible in the car. (This writer once had a car broken into for the mere 35 cents left in the open change holder.) If possible, put any valuables in the trunk before you park, so that no one is watching you stow your stuff curbside. And more importantly, be proactive in securing your car by layering it with anti-theft protection like a starter disable switch, a wheel lock and a car alarm.
    9) Approach with caution. Driving is made exponentially more difficult if you're new to a city. Locals know which roads to avoid, but strangers do not. It pays to check ahead of time to see if construction has turned your chosen path into a virtual parking lot. If a two-lane interstate becomes an eight-lane expressway as you approach the city, get into one of the right-hand lanes. This allows you to slow down enough to read unfamiliar signs. If your exit sneaks up on you and you're not in the correct lane, don't try to cross several lanes of highway traffic to make it. Let it go. Then get off at the next exit and work your way back if necessary. If the next exit is a ways off, check a map: Triangulating to your destination might be faster than doubling back on the highway.
    9) Use navigational aids. Good navigational aids are useful at any time, but particularly if you're traveling to a new city (or an unfamiliar part of it).
    If you do get lost, take a deep breath. Allow yourself to be late. If your car doesn't have a built-in compass, can you reorient yourself the old-fashioned way, using the angle of the sun? (Or if you're really good, the position of the stars?) If that doesn't work and you have GM's OnStar, now is the time to make that subscription work for you. If not, pull over to a safe area, then ask for directions. Sounds simple, but how much time is wasted before most people admit they need a little guidance?
    Finally, the best advice one can give about city driving is not to sweat the small stuff. Cabbies may cut you off, pedestrians may jaywalk, drivers may rubberneck, but you'll get there — eventually. The real trick is to keep your blood pressure down and your spirits up.
    And don't forget to feed the meter.
    Jun 2005
    My only TIP for city driving is minimize the use of your car (only when necessary).
    Jun 2005
    tip: ingat sa MAPSA lalo na pag malapit na lunch or dinner time
    Jan 2004
    for those who cannot avoid to use their vehicles (like me), ok lahat nang binanggit sa itaas. pero personal observation ko, if you try to maintain your speed on 60-80 km/h average, staying in lane and sticking to 2000 rpm. fuel efficiency can be achieved. one advice though, lalakas nga lang ang konsumo mo sa kape. soooobrang bagal nitong speed na ito...
  5. #5
    If the weather permits you too, shut off the airconditioner. Also check your tire's air pressure.
    Jan 2004
    anticipate. anticipate by keeping distance from the vehicle in front of you. driving by anticipation will save you time from stepping on the brakes abruptly. abrupt braking waste gas.
    also drive consistently. if you can keep a steady foot in the accelerator, the better. because, accelerating and decelerating unecessarily also waste gas.
    Sep 2005
    my fuel saving habits:
    1. in traffic, when the car in front of me moves forward just by a foot or two...i don't follow it unless tuloy tuloy na daloy ng lane. yun nga lang, the car to your left or right will most probably try to cut into your lane with that extra foot or two of space in between you & the car in front of you. bwiset!
    2. i lower the output of the sub (head unit feature) when driving. it kinda reduces engine stress. i notice that my engine responds significantly slower when the sub output is high (for high wattage subs)
    3. i have this technique (in A/T cars) with the gas pedal. i don't slowly press down on the accelerator, i sort of tap it & leave my foot on the pedal to get it up to speed (don't really know if this helps. technique ko lang. hehehe)
    4. tire pressure is at 32-34psi (215/40R17 tires)
Top 10 Tips for City Driving
