Results 1 to 19 of 19
    Mar 2003
    rainy days ulit and question lang mga ginoo pano mawawala ang squeaking sound sa nabasang fan & AC belts? masama ba ito? :?:
    pag nag dry yan mawawala ang tunog. natural po yan.
    minsan sign yan na dapat ng palitan
    Jan 1970
    kelangan na ba palitan? i have mine sqeaking nong umulan ng malakas. its an instant attention grabber hehe.
    Usually nawawala iyan when the belts and pulleys dry out. Do a visual and tactile check if the belt tension is not too lax or too loose. Check the condition of the belt itself both with the engine on and with the engine off.
    Jan 1970
    thanks for the suggestions otep. i will try to check.
    Apr 2003
    when it dries and navisual check mo na at ok naman try mo din lagyan ng belt dressing. 3m or yung bondo. mas maganda daw bondo coz of the way it is applied. para syang pomade stick yata. :mrgreen: yung 3m is spray.
    Yung 3M messy. Hehehe. Sinubukan ko sa lumang Pajero dati. :mrgreen: Nakaka-high pa ata ang amoy.
    saan nakakabili nyang belt dressing? (parang salad a). ganyan din fan belt ng patrol ko. nakakahiya dahil sobra ingay. yung mga katabi ko minsan na passenger jeepney napapatingin sa akin. :mrgreen::twisted:
    Signature
    baka kelangan lang higpitan.
    Wait till its dry kung meron pa tignan mo kug kailangan higpitanm kung di matanggal palitan mo ng bago better get the grooved ones medyo tahimik ito.
    Mar 2003
    Quote Originally Posted by icon
    bro icon, pang tanggal lang ba ng squeak ng fan belt 'to? anu pang ibang advantages pag naglagay ka nito? di ba dudumi yung belt mo, mag- accumulate ang dumi?
    thanks 8)
    ako nilalagyan ko ng grease...ewan ko kung nakakabuti yun
    pero ok naman..heheehhehe
    Quote Originally Posted by ozcity
    mawawala ang squeking sound nyan pero dudulas naman, palagay ko mas problema yon.
    Apr 2003
    I don't think magiging madulas yun. And yung formulation nya is para d kumapit masyado yung dumi.
    Di ko din exactly alam how it works. :mrgreen: But I haven't heard of any direct bad effects of using belt dressing.
    Pagtama ang belt tension kahit wd40 pwede in most cases have done this many times at ok naman ang result. But firts check first the belt tension and pulley alignments.
    Mar 2003
    ganyan parati nangyayari sa lancer ng sis ko. we thought it was the belts or something. we had it changed pero bumalik pa rin. yun pala bearings. check mo rin.
    Apr 2003
    sir, mas ok siguro if you get a belt dressing na lang. It works naman yata on the belts. WD40 is like oil so baka mag"glaze" yung belt mo and maging mas madulas, mas prone pa siguro to squeak yan.
    Quote Originally Posted by GoThicbLuE
    Quote Originally Posted by lapuks
    mawawala ng squeking soung nyan pero dudulas naman, palagay mas problema yon.
    wag lang masyado madami dudulas talaga yun..
    konti lang nilalagay...ok pa naman..hehehe
