Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Mar 2015
    Anyone who tried this product named seafoam motor treatment?base sa experience ko ok sya.luminis ang loob ng makina at pumino ang idle nya sa honda R18 engine ko
    Sent from my E6853 using Tsikot Forums mobile app
    Quote Originally Posted by 27 View Post
    how does one know, na luminis ang loob ng makina, without having to open it?
    pumino idle.. at gumanda performance, even... i get the same effect after an change oil.
    Mar 2015
    Sinilip ko sa may oil cap.dati may parang varnish na kukay ngayon wala na.mejo may tikking noise dati parang nawala din
    actually, the name is... "non-reassuring".
    foaming has a negative effect on engine lubrication.
    Jul 2006
    Where is that sold?
    Not all gunk is bad, but then again I guess you motorheads know that.
    Aug 2004
    Where is that sold?
    Didn't know it was available here, actually.
    The guys on the enthusiast forums have been using it for decades. Works great for old engines with lots of gunk and deposits.
    On a relatively new engine, it's not necessarily needed.
    Apr 2012
    Quote Originally Posted by cliford27 View Post
    Where you brought it and how much?
    Sent from my LG-H818 using Tapatalk
    Jan 2009
    I will have to read up more on this. I'm always adamant about putting any miracle do-it-all product in my fuel tank or engine.
    Mar 2015
    Nasa Cayman Islands ako sir.very popular yang product na yan dito.most mexhanics recomend it due to driving conditions.Mainit at traffic parang pinas
    Jul 2006
    If I were in the Cayman Islands, I'd be looking for a different kind of sea foam. And the things that go with it.
    Mar 2015
    Pwede rin seaweeds bro.haha
    May 2012
    YouTube - CrisFix
    Sent from my SHT22 using Tapatalk
    Mar 2015
    Quote Originally Posted by jyg1995 View Post
    YouTube - CrisFix
    Yes bro ganun ang ginawa ko.pinasipsip ko sa vaccum line yung 1/3, at 1/3 sa gas tank, 1/3 sa engine oil
    May 2012
    Yung sa vacuum at sa fuel tank sir mukang ok kaso ung sa pag hahalo sa engine oil ang ayaw ko hehe baka Hindi ma flush lahat tas pag refill ko ng oil labanan din nya baka may part na hindi mag bond ung oil.san ka binibili sir? 800 din ba?
    Mar 2015
    Nasa cayman islands ako sir.worth 20$ yata bili ko last month nyan.wala naman ako napapansin na bad effect nya sa engine ko.ang napansin ko natanggal ang varnish color sa loob pag sinilip sa oil cap.ang ginawa ko habang nagdredrain binuhusan ko ng extra oil kaya sumama na mga dumi.* 400kms,looks like new parin ang oil very clear
    Mar 2015
    Ginamit ko sya sa honda stream ko R18 ang makina.pwede din daw ito sa diesel ihalo gas tank or as diesel purge.ibuhos sa lalagyan ng filter.Balak ko nga gamitin pag uwi ko sa monty ko.hehe
    Jun 2018
    Hi sir tama, most likely sa america tong brand kasi na to ang mataas or maganda ang resulta sa dami ng nkalaban nyang carbon & sludge buildup cleaners. Para mas macheck ninyo sir ung buildup ng enginge without baklasan ng engine is you could use borescope tools if n.a. You can simply check it with your bare eyes sir pagnabaklas nyo sparkplug nyo then makita mo dun possibly may carbon na piston head nyo sir experienced ko na kasi un. Actually mas maganda sana if nacheck mo na ung honda mo before pa man natry ung product. Lam ko sir 2 times up to 3 times before clean up ng maige ang engine natin. Then thoroughly check nlng engine sir.
    Jul 2014
    Quote Originally Posted by Heady View Post
    Saan makakabili nito sa Pilipinas?
    Sent from my SM-G7102 using Tapatalk
    Oct 2018
    Quote Originally Posted by Mask Rider Blac View Post
    I got mine from Lazada nung CNY Sale. I used it with my 2013 Everest, immediate ang effect niya. Less vibrations, engine noise and throttle response.
    Feb 2019
    Anyone who tried this product named seafoam motor treatment?base sa e Xender Discord Omegle xperience ko ok sya.luminis ang loob ng makina at pumino ang idle nya sa honda R18 engine ko
Seafoam Motor Treatment
