Results 1 to 15 of 15
    few mos ago i almost bought this suv....it's CUV Hover from a local manufacturer here in china called "Greatwall".
    do u like it?
    no thank you.
    Oct 2005
    it looks nice. parang familiar ang itsura.
    i'd want it if they're going to sell it here dirt cheap.
    depends on the "quality".
    looks nice nga ah... :D
    Dec 2004
    Mukhang Isuzu Axiom..hay naku sana ilabas yan dito!
    Mar 2004
    Hey! Why not!
    Sep 2004
    CUV better not mean Counterfeit Utility Vehicle or worse, Crappy Useless Vehicle.
    Astig features ah:
    -- Mitsubishi 4G64 engine, meets Euro-III emission standard, with Delphi multi-point ele-fuel injection system.
    -- Front Dual Airbags Equipped with advanced electronic smokeless airbags. Siemens ECU calibration. SRS system normally react within the range of around 120°.
    -- 17 Inches Big Rim Soft interior plus aggressive outlook
    -- Rear Combined Tail Lamp Vertical rear lamps
    -- Electronic instrument panel with adjustable lightness function. It adopts international advanced instrument microprocessor, can collect and deal with signal from sensor.
    -- ABS+EBD Equipped with most international advanced ABS system: BOSCH 8.0. Higher steer stability, better brake force distribution, safer driving.
    -- German WEBASTO Sunroof.
    -- Smooth Interchange of 2WD and 4WD Adopt power clutch control and interchange 2WD and 4WD smoothly.
    -- 5-speed Manual Transmission
    -- 4-link coil rear spring dependent suspension, double fork-arms type, independent suspension, absorb the road shock power and bring you safety and comfort.
    -- Super-stable Chassis System 2700 mm wheel base and 1520 wheel track, turning more stable and shock absorption more effective.
    -- Hydraulic power steering with fail safe function.
    -- 200mm Ground Clearance Strong trafficability. 235/65R17 widen and enlarge tyre ensures performance and safty.
    -- Warm-toned Inner Decoration Up-part with weak color, under-part with dark color,and adopt non-radiation environmental material.
    -- Genuine Leater Adjustable seats 4-way power driver seat and 4-way manual codriver seat. Rear row backrest is 3-way adjustable and the seat design accords with ergonomics.Depth of the seat up to 480mm,brings you embrace feeling.
    -- Combined Crystal Diamond-shaped Headlight Crystal diamond headlights have strong visual impact.
    -- 6 disc CD Electronic unti-shock system, quadriphoy vedio and bass system make music sound perfect.
    -- VFD Super Display Screen Blue fluorescent display screen combined A/C and CD player. It collects kinds of data and deal with them separately.
    -- Power Window Control convenient, luxury and comfortable. Centrol door lock with remote control chip has 30 second guard against theft function.
    -- Manual and Automatic A/C More convenient to control. Equiped with air filter fitting up to environmental requirement.
    -- Inner Mirror with Manual Anti-dizzy Function
    -- Rear Window Defogger
    -- Exquisite Craftsmanship CBU adopts digital design and development, car body is welded utilizing group control technology and bored hole by robot.
    -- Car Body with Three-layer Painting Cathode electro-coating strengthens rust prevention function. Floating coat adopts international advanced painting equipment,besides middle and upper coats are painted by Japanese imported robot.
    Jan 2003
    The CUV is a front wheel drive vehicle fitted with a mitsubishi engine. Available in 2WD and 4WD. Nice-looking SUV. Price quoted to me when I visited one of the Great Wall showrooms in Guangzhou four months ago is RMB 126,800 (around PHP 887,000).
    Basta may murang parts at madali ayusin, ok lang naman.
    Dec 2003
    :bwahaha:I hope not..hehe
    Basta Quality and Parts at madaling ayusin pwede na..
    Huwag lang tulad ng Geely yan ah..
    looks good! pero tayong mga pinoy alaws bilib sa gawang china kaya tyak pag dinala dito yan konti bibili.
    sabi na nga ba when i looked at the pics parang based siya on the montero sport..tapos sa specs niya mitsu engine..pasok nila mga 700k-800k may bibili din niyan kung stavic nga may bumili eh
    As long as there's parts availability and the price and quality's ok may bibili niyan.
    actually astig syang tignan...... dia ba? i would consider it for now the best "local suv" here in china...dami kasing naglabasang isuzu alterra-look-a=-like suvs d2 na nakakasuklam...hehehe!!!
    anyway thw reason i did'nt buy it is that the handling, for me, is not that comfortable. lalo yung driver's door eh masyadong makalpal yung upholstery kaya medyo uncomfortable sa left arm ko. tska medyo nabibigatan ako sa clutch nya..kakangawit sa low gears. interior wise pede na...ayoko lnag yung rustic yellow shade nya...parang sh.t!! anyway overall impressive n sya lalo yung Mitsubishi 4G64 engine at ibang " specs" nya.
CUV HOVER....do u want this in phil?
