Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    I had an afternoon EB with Turbo a.k.a. Mr. Deo in Bulacan this afternoon to check out some pony cars for sale in the area for a new prospective project.
    I was really awed with Deo's collection of Muscle Cars especially his on-going "ELEANOR" project. Turbo is your quintissential muscle car enthusiast bar none. I was especially impressed that he has the ability to even fabricate some unavailable parts (suspension parts etc...) thanks to his conveniently located machine shop.
    Turbo accompanied me to a distant place (about 15-20 kms from his place) where Mang Radie lives. You would think that this was the last place you can find some restorable Mustang cars. Lo and behold, I easily counted 6 to 7 pony cars in Mang Radie's garage complete with engines and parts.
    Guys, if you are in the lookout for possible car projects, check out Bulacan since you may be surprised about the preponderance of a number of desirable old "junk" cars available for restoration.
    Thanks Woodfire for the complement, but I am just a regular guy we loves Muscle cars.
    Its just that my father owns a machine shop and I was an apprentice even before most oy you here was even born. I learned to make designs at an early age and have no fear to apply it on my cars. Cguro malakas lang ang loob ko.
    Regarding mang radie, i just want to help the guy, and ofcoarse I want the Mustang to have a comfortable and caring home. So guys, jump on the Muscle car band wagon and start to own one.
    There is no replacement for displacement.
    Thanks Dindo for the fine afternoon, sorry that I can't entertain you so much, ginagawa pa
    bahay ko.
    I've been to Turbo's shop months ago, what can I say... the man is a genius. We need more "real" car afficionados like him. Plus, he's willing to help anyway he can. Great man.
    And I still haven't fixed my darn master cylinder...
    Mar 2003
    hello turbo! how's the camaro doing in your shop na? i bet your doing wonders with it. give my regards to jack =)
    The camaro is now running and purring like a ferocious cat. Got the flex plate the very next day from Dexter(remember Bunny?). Had it running the same afternoon when the flex plate arrived. Just a little cleaning on the rear brakes was needed and it is road worthy again. Had a spin aroun the block. Huge tires, reminded me of my 68 vette with N50 Mickey thompsons. You have taken care of the camaro very well.
    Bunny, binobola nyo na ako ni Dindo. Regular guy lang ako, actually hangga ngayon nag-aaral pa din ako ng tungkol sa muscle car.
    Natandaan ko tuloy yung 71 Corvette ko, binili ko ng surplus na 6-71 blower sa Evangelista Quiapo. tapos binili ko ng dalawang 4 barrel na Holley, nong nag-fabricate na ako ng intake manifold para don sa 350 engine ng Corvette, nakita ng tatay ko. Galit na galit sa akin, tinago yong 2 Holley, tapos pinamigay yong 6-71 blower. 26 years old lang ako non. Hehe.
    Bunny meron pa akong master dito. Ano ba ang probleme pa ng brakes mo.
    Hehe, di ako genius, bobo nga ako lalo na sa mga bagong fauel injection.
    wow.. an ELEANOR project car. A couple of weeks ago Discovery channel's RIDES program dedicated a whole episode about the Mustang Eleanor. The car in the movie is designed by Chip Foose. BUt they also showed a company which exclusively sells ELEANOR replicas. They use plain old Mustangs and convert them.
    any pics??? :D
    May pics na, kaso sira ang scanner ko. Tapos d pa ako sanay magpost ng pics.
    Actually meron nang isang tapos na. The owner has already taken delivery. Meron pang dalawa akong tinatapos.
    The two is taking alittle longer to build because they will both have the 460 Powerplant, the biggest that Ford can offer. The engine usually resides inside Lincolns, LTDs, full size vans ang F350. Both cars will have rear disc brakes with cross-drilled and slotted discs. Fron end will have 4 piston calipers anf huhe 13" cross-drilled and slotted disc.
    front suspension will be tubular A-arm and rack and pinion steering. Rack and pinion is a critical change to tame the dreaded Mustang steering. rear end will be full-floating ang coil-over shocks.
    Engine modification will differ, and that will follow.
    I hope to complte one before April.
    Deo,
    Nag-lolock and front left brakes. Ayaw bumalik agad pag tumapak ka. Umusok nga one time, akala ko nag overheat ang makina. Ginarahe ko muna for the meantime. Same thing with the dual MC you gave me, I'm still dumb where to start.
    I just don't have the time to fix it myself coz of my erratic schedule at work.
    I texted you about the 75 Camaro, do you still have the same number? Wala ka pang reply.
    Bunny
    Naiwan ko sa Mercedes yung cell ko ngayon. Same number pa din.
    Madali lang yon problem mo. Kung nalinis mo na yung wheel cylinders. Tanggalin mo yung rubber hose. Clogged na yong. Luma na ciguro. Pag parang clogged na, palitan mo ng bago.
    And the last to look at is the rod that pushes the master cylinder. Dapat may clearance na atleast 1/8" before engaging. Pag tukod or naka-engage agad ang pash rod, the pressure on the cylinder will buid up, until the shoe won't back up anymore.
    Two point to look at:
    1. Rubber hose that feeds the brake that get stuck.
    2. Push rod clearance. Must not be pre-loaded(tukod).
    Oct 2004
    nakita ko din yun... astig nga e... great way to bring those old ponies back to life, ang ganda pa ng pagka-restore nila.
    sir turbo, san po sa Bulacan shop niyo? baka pwede ko silipin Eleanore project niyo minsan kung madaan ako diyan... interesting.
    san po kyo sa bulacan? I always go to bulacan(guiguinto, sta rita)
    178 Biniang 2nd Bocaue Bulacan.
    Sayang hindi ako nakapunta kina turbo nung ginagawa pa lang yung Ford namin.
    Btw, the next project is on its way (coming early 2k5). Pero dito na lang sa Metro Manila ginagawa.
    Dream project ko pa din ang 1975 Datsun 180B.
    Dec 2004
    how much po convertion nung eleanor?
    Apr 2004
    parang exotic cars galore na sa bulacan ah, napansin ko. dati may mga lambo kaya muscle cars naman...
    Turbo has a "screaming yellow" Corvette parked in Bulacan! Now that's my ultimate muscle car!!!
    Dec 2003
    wow...
    Wow. Muscle cars aficionados! That is quite rare here sa pinas. Most people go for the Japanese pocket rockets.
    When I was in high school, my brother in law had a 72 charger. Man, did that car drank gasoline! But the sound of the V8 was soooo good!! My father had some american cars back then but not really muscle cars. Some Ford Fairlanes and Falcons. But they were built tough.
    I still have this passion of finding a 1969 Dodge Charger, similar to the one in the Dukes of Hazzard, and restoring it like new. I like its styling and also the engine. I found one on Ebay selling for $500 dollars, Problem is, it will cost me more bringing that car here and have it restored here. Another car I would like to build is an AC Shelby Cobra. Even a kit car would do nicely because an original will set you back a lot!
    I bought my near junk '67 Mustang Convertible (V8-289c.i.) in Bulacan c/o the help of Turbo. It is also being restored piece-by-piece by a Mustang expert(rare nowadays) in Bulacan. Some of the performance parts were also bought in Bulacan c/o Turbo such as Edellbrock performance intake manifold and holley(or was is autolite?) 4-barrel carburetor. Most of the parts though will be ordered & sourced in the U.S.
    With the entry of the New Year, Turbo has two new muscle babies in the form of a 1970 Chevelle and 1969 Camaro now parked in Bulacan!!!
    Quote Originally Posted by woodfire
    sir woodfire please post restoration progress pics if possible. i find restoration projects interesting.
Muscle Cars Galore in Bulacan!
