Results 1 to 12 of 12
    May 2004
    anong magandang pang-rustproof sa mga nuts and bolts sa ilalim ng sasakyan, dito kasi nagsisimula ang corrosion. okey bang gamitin ang engine oil?
    Actually, unless you replaced the bolts and nuts with substandard ones, they don't rust. Manufacturers use anodized bolts and nuts that just don't.
    May 2004
    Quote Originally Posted by theveed
    dito kasi naglalagay sila ng salt sa kalsada para wag magfrost yong daan kaya mostly yong nuts and bolts ang unang kinakalawang kahit pa yong original. gusto ko kasing lagyan ng kahit na konting langis or any sort of protection man lang in a few days. May nagsabi sa akin na okey daw yong engine oil na gamit na but I don't mind using kahit yong di pa gamit (yong mumurahing langis lang).
    pwede kaya wd-40?
    If that's the case, just use some grease and dab over it.
    Dec 2004
    You can use a special type of grease commonly called "pneumatic grease", mostly use in oil and gas industry to protect the bolts and nuts to fuse caused by metal corrosion/errosion.
    spary it with "ZincIt" (zinc it) cold anodizing paint. or why not undercoat the whole underbelly of your car? winter dyan ngayon, so make it a point to wash your vehicle at least every week.
    Jun 2004
    Engine oil could harm the paint on the bolts (if painted) and area around it. Grease would be better.
    May 2004
    Quote Originally Posted by yebo
    wala yatang nag-uundercoat dito, wala pa kasi akong nakikitang gumagawa nito eh unless DIY.
    Quote Originally Posted by chris_d
    harmful ba sa paint yong engine oil?
    Sasamantalahin ko na rin po ang pagtatanong, may konting bubble ng corrosion yong likod ng rubber trim ng pinto ko at gusto kong i-grind para matanggal yong kalawang, anong dapat kong ilagay once na nagrind ko na. So bare metal na yong nakalabas, ano bang ginagamit ng mga bodyshop para dito?
    mas gusto kong ako ang gumawa basta alam ko lang ang dapat gawin at least masisigurado kong tanggal lahat yong kalawang. Sa mga bodyshop okey sila kaso minsan sa kabisihan minamadali kaya after few months ayon balik na naman yong bubble. thanks.
    merong spray-on teflon for bolts or yung rubberized undercoat in spray cans pwede rin.
    sa bare metal you have to put some body-filler then lihain mo, tapos paint mo. wag mo pababayaan na exposed ang bare-metal tyak kakalawangin yan.
    Quote Originally Posted by Wouie
    pare nasa US ka! punta ka sa Pep Boys or similar shops. meron dun rust converter, either in can or pen. yung pen it is like a felt tip pen, kulay yellow yata if i remember it right. lihain mo lang konti yung rust then "paint" it using the pen. maging color black yung rust/bare metal. then pwede mo na lagyan ng body filler (masilya sa ating mga pinoy), sand paper then spray paint. sabihin mo lang model, brand and color ng car mo alam na nila kung ano ang spray paint can na ibigay nila sa iyo. pag na-paint mo na then polish with rubbing compound, good as new ulit yan.
    Or use POR-15 (go to their website)
