Results 1 to 10 of 166
- Jun 2008
- 1,741
March 31st, 2012 10:27 AM #1I think this truck is about a copy of Toyota Tundra (my guess). Tumagal ako dito sa ka-inspection. Pati ilalim tiningnan ko. Ayon sa Foton global website ang tranny is from cadillac and rated 2.5T truck. I have no reservation that cummns engine is a tough one (beat isuzu technolgy in my own assumption). Di ko lang sigurado if the turbo is vgt or non-vgt, walang tao doon na makasagot sa tanong ko eh. Kulang-kulang kasi ang technical specs sa bronchure nila. One thing is sure: engine by cummins & fuel injection system by "Bosch" of germany (the same common rail system use by Hyundai-KIA). I can't wait to test drive this pick up.
At 878K the 4x2 manual, yes bang for the back I should say.Last edited by weisshorn; March 31st, 2012 at 10:33 AM.
March 31st, 2012 11:02 AM #2
WOW! kung ang price talaga nito eh between 900000 to 1000000 pesos (4x4) ... then this is worth a second look.
Kasi sa size lang... parang kasing size na nun bagong Ford Ranger...
Based sa specs sa papers... OK din engine, tranny, etc...
Sana nga totoo.
March 31st, 2012 11:06 AM #3
March 31st, 2012 11:18 AM #4
- Jun 2008
- 1,741
- 172
March 31st, 2012 12:26 PM #6110 kW (148 hp) at 3600 rpm, with peak torque of 360 Nm (266 lb ft) at 1800 rpm. Life to overhaul is expected to be 500,000 km. (quoted from SinoDiesel.com)
impressive numbers indeed. i can personally vouch for the reliability and durability of the cummins, but still has reservations on the ladder chasis and the front suspension.
- Jun 2010
- 452
March 31st, 2012 02:39 PM #7Looking at the pics, mukhang Hi-Lux based nga itong pick-up ng Foton. Side and rear pics remind me of the Hi-Lux.
- Jun 2008
- 1,741
March 31st, 2012 04:30 PM #8according to the bronchure and global foton website this cummins ISF2.8L CRDi engine is rated at 120kW.Front suspension is double wishbone and leaf spring in the rear. I visually check the ladder frame (including the welds) a.nd it looks ok to me, not much different from that of toyota & mistsubishi
- 172
March 31st, 2012 05:04 PM #9[QUOTE=weisshorn;1901400]according to the bronchure and global foton website this cummins ISF2.8L CRDi engine is rated at 120kW.Front suspension is double wishbone and leaf spring in the rear. I visually check the ladder frame (including the welds) a.nd it looks ok to me, not much different from that of toyota & mistsubishi[/QUOTE
then its sticker price is a steal. the cummins engine is quite reputable for truckers, since its a newly developed engine i hope the lineage of its big brothers (million milers) runs thru its veins errr oil galleys. 500,000 kms before an overhaul is impressive, if it really is, the body would have corroded into bits and pieces before the engine has to be pulled down.
btw my last engine pull down was a TD25 at 240,000 kms.
April 2nd, 2012 01:57 AM #10
Maganda tong Foton Thunder..Mas mukha pang maayos to kaysa sa Hilux E 4X2.
May Dual Airbags at ABS yung 4X2 variant!
Ongoing problem pa din Pala ito even among euro cars ...
Takata Airbag Problems
