hindi yung pinasok ng tubig yung engine.
kasi we usually hear, not to wash your engine when it's hot, since the sudden change of temp might damage your engine.
or are diesel engines immune to this?
alam ko - not to pour water in a radiator of an overheated engine that is not running. it might or will crack your engine block. You should be concern if the water enters your intake manifold through your air filter housing. No problem with the muffler as diesel engine can idle even if the muffler is underwater (see my avatar). :wink:
hybrid,
Never pa naman may nangyaring masama sa amin while fording although hindi nga recommended dahil sa sudden drop in temperature. Even the axles and tranny are hot.
Don't worry so much. Hindi naman mag-flood suddenly into the engine compartment yung water when you ford.
Mas importantend hindi pasukin ang intake mo.
Si afrasay ang naval officer namin sa DieselClub. :mrgreen:
buweset :twisted:
gusto mo sa jollibee east ave. yon sa corner ? i'm also passing there.
afrasay,
Yung malapit sa LTO? Napaka OT ata ng usapan natin. :mrgreen:
bilis niyo sumagot a :D
mukhang nagpupuyat din kayo
otep,
early this evening I saw like 8 defenders park along roxas blvd. near aristocrat area, galing talaga. sila olive kaya yun?
afrasay,
7am pa? Hehehe. Oks lang saken pero hintayin mo ko. Wala ka bang alam na 24 hour pares place or sumthin?
hybrid,
Excited na ko, eh. Kanina pa ko nag-aayos ng rig. Post ka lang questions or text us.![]()
Along katipunan. lalabas kasi ako doon. baka may alam ka. ah, goodah mayroon pa ba doon?
afrasay,
Sa Tropical Hut na lang sa may National Bookstore Quezon Ave. 24 hrs yun.![]()
otep:::cge. what time ka dating?
hybrid:::just be sure walang butas yon hose from your air cleaner going to your intakes. also take note of the height of you air cleaner as this will determine the height of the water you will ford.
CaRGirL:::sorry po.
afrasay,
Ok see you there. I have other things to attend to afterwards diba? hehehe. :mrgreen: Libre mo na lang ako ng meal number 1. hahaha.
cge. see you there. 2log na ata si hybrid. goodnight hybrid. goodluck on your lahar trip.
While reading an article sa kakayanan ng humvees na lumusong sa tubig....ang namention nila lang ay - all the breathers ng axle, transmissions, and engine are all connected to the air intake/filter chamber....therefore it's waterproof.Originally Posted by hybrid
I don't think magkaka-crack din...unless natuyuan na ang engine mo ng tubig at uminit ng husto....kasi water-jacketed din naman yung block...unless super taas ng temp ng makina then sudden drop ito ng biglaan.
my 2 cents.
afrasay,
wwwaaaahhhh.....:cry: hindi na kami pupunta sa expo
yung mga kasama ko nagback-out :roll:
peace.....:D baka batuhin ako
Based from my experience, I only found out when I replaced the clutch assembly. The old clutch disc and flywheel had water spots. The water didn't enter the clutch assembly though maybe some sprinkle at the most. These water spots are caused hence by its name suddenly touching any hot metal surface. And also water spots are harder to be manipulated by lathe machines.
sir hybrid,
nakita ko din po yan! i was amazed.. nung una isa lang nakita ko... tapos sunod sunod... para po akong ganito kagabi o....
wow!! 8O Defender!!....Defender....defender...defender....d efender.....Rover! 8O
hehehe... natulala po ako!!!
ano kaya dun mag-EB ang DC.org?
hehehe... OT na...
btw, sir Ungas is an expert in river fording! :wink:
check this out
Ungas' Submarine
Hahaha, not an expert, just a dumb move that's all. :mrgreen:
And before I forget something, NEVER step on your clutch while submerged in deep waters!
