Results 1 to 11 of 11
    Aug 2008
    Hi tsikoteers,
    need advise po kung papano maayos ang hatak ng kotse? mahina kasi sa akyatan ung oto ko and i dont know kung ano ba dapat paayos? sa rekta wala namang problema. change engine na ba kailangan nito? sorry guys super newbie ako. salamat po!
    ipa-road test mo muna sa kilala mo na mekaniko para malaman kung tranny or engine ang problema
    daming kailangang i-test.
    a. una, condition of the engine. may smoke ba na lumalabas pag umaakyat? when was your last tune-up? palyado ba? fuel lines? electrical?
    b. transmission. dito medyo madami-daming test.
    tama si bambino. pa road test mo with a mechanic.
    Aug 2008
    Thanks po sa lahat ng suggestions.
    Wala naman pong smoke pag pa akyat. Last po na tune up ko was i think 8 months ago pa. May recommended po ba kayong shop para mapa check ung oto?
    Salamat po ulet!
    lagi ba siyang mahina, o biglang humina recently?
    kung lagi siya mahina by your standards, maybe it's a question of realistic expectations. a 1.3 or 1.5L engine (tama ba) with 1990 engine tech is not going to have great climbing power no matter how well taken-care of it is...
    Oct 2003
    Have the carburetor tuned-up. check spark plugs, air filter
    i think your problem may be two things ...
    1st problem may be is your tranny ... or your clutch ... baka sliding na kasi kaya walang hatak ....
    2nd problem siguro yung fuel filter barado or your carburator needs tuning or a little adjustment or better yet carburator cleaning ...
    if you are near banawe ... you can go to my shop for test drive
    BANAWE AUTO SUPPLY
    7120115
    regy
    Or maybe it's your engine na, better kung ipa-compression test mo na din, ask ka nalang kahit sa mga gas station service kung meron sila nun or any mechanic/service shops (like SpeedyFix) on the know-how methods on checking the compression and/or other irregularities on the engine and performance.
    Good Luck. :D
    Aug 2008
    ok po thanks po sa lahat ng advice
    Nov 2003
    when in doubt bring it to your mechanic and have them check it to see what is wrong. a personal diagnosis is always better than one over the internet
Corolla 90XL5: Mahina ang hatak at sa akyatan
