Results 1 to 5 of 5
    guyz, what do you think of this? now ko lang napansin to. and my oil level is down at 3/4 . last time i had my oil changed(0w-40), pinuno ko siya at max level. oil leak kaya to mamasa-masa na to? hinwakan ko, parang baby oil yung texture.
    eto pics:
    Valve cover gasket ba.
    Quote Originally Posted by speed unlimited View Post
    its the cover above the engine, covering the cams and valves. oil leak kaya to?
    Most likely engine oil...masyado ksi malabnaw yung 0W-40 kaya lumulusot sya sa gasket. I also drive a 3ZZ pero choice of oil ko 20W-50...malapot at mas mura pero it does the job.
    Change valve cover gasket at mawawala din leak nyan.
    up ko lang po
oil leak on 3zz?
