Results 1 to 8 of 8
- Apr 2009
- 272
June 22nd, 2017 08:26 AM #1Im planning to change my timing belt and failing water pump already, what other parts should i also change para sulit sa labor?
- Jul 2010
- 165
June 22nd, 2017 08:45 AM #2
- Apr 2013
- 236
June 22nd, 2017 10:30 AM #3Sa 4afe gli yan? Sama mo na din yung mga drive belts. Alternator belt, ps pump belt, compressor belt. Optional lang naman yan. Bando is a good brand.you might as well change the spark plug oil seal since nasa valve cover naman yun at magbubukas din ng valve cover. Pero optional lang din naman yan. Camshaft and crankshaft Oil seal, timing belt,and water pump talaga ang "must change" dyan.
- Apr 2013
- 236
June 22nd, 2017 12:24 PM #4Timing belt
Tensioner bearing
Camshaft and crankshaft oil seal
Water pump
Optional:
Ps belt
Altenator belt
Ac compressor belt
Spark plug oil seal
June 22nd, 2017 12:24 PM #5
Sa ibang models ng kotse, meron mga idler bearing/s na dapat din isama sa pag-palit.
Then may balancer belts pa.
- Apr 2009
- 272
June 22nd, 2017 07:37 PM #6Car ko pala is corolla 1997 1.6 gli 120k mileage Napalitan na yung oil seals crankshaft and cam shaft 3 yrs ago so ok lng palitan ulit? By the way pwede ba to pagawa sa servitek? Kaya ba nila ang ganun service?
- May 2011
- 481
June 22nd, 2017 09:09 PM #7The timing belt kit includes:
Timing belt
Camshaft seals - 2ea
Front crankshaft seal
Idler pulley
Tensioner pulley.
Not included is the oil pump seal
All these parts need to be replaced for your 4afe.
This task takes about 3.5 hours by an experienced technician with the necessary tools.
- Apr 2009
- 272
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
