Results 1 to 5 of 5
June 25th, 2008 08:59 AM #2
June 25th, 2008 10:06 AM #4
thanks sa mga reply. papalitan ko po kasi ang mga terminals and mag iinstall ng grounding kit, may nakapagsabi na marereset ang ecu kung makukuha ang terminal for more than 10 minutes.
June 25th, 2008 10:47 AM #5
Resetting the ECU can either be beneficial, depending on what it has "learned" in the past three or four months. Some ECUs learn wrong, make less power and consume less gas. Some ECUs learn right and make more power. Either way, I wouldn't actually lose any sleep about it. After two or three days, the ECU will adapt again, anyway.
PV=nRT you know
