Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Jul 2006
    tumaas po ang fc ko after replacing timing belt.ano po ang problema?
    baka naman it is skipping a tooth. unlikely, but the only explanation I can think of...
    replacing timing belt lang ba ang pinagawa mo?
    May 2007
    Kung palit lang ng timing belt. I would suggest to tune up your car also and re-time the timing.
    Aug 2004
    Have them check that they replaced everything properly... do you experience a loss of power? Having the belt off one tooth will negatively affect performance and fuel consumption .
    Nov 2003
    yeah, it shouldn't be affected by the timing belt unless it was incorrectly installed.
    Jul 2006
    tinanggal din po ang battery for almost an hour, may effect ba yun?
    Quote Originally Posted by ej_saiyajin4 View Post
    kung may computer na yung ride mo.
    Aside from the the fuel consumption, how about noise, smoke, temp, power and response?
    Jul 2006
    Quote Originally Posted by rion View Post
    yes po efi po.
    Jul 2006
    Quote Originally Posted by 4JGtootsie View Post
    sa noise,smoke, temp wala...pero power slight and medyo mabagal ang response.
help! FC tumaas
