Results 1 to 20 of 21
    Hi mga Sir,
    Sorry po newbie lang ako pagdating sa mga car parts... recently nagpa change oil po ako sa Honda Shaw for my 95 Honda Civic Lx na 2nd hand and they found some oil leaks... so pina quote ko po kung mga how much po magagastos ko eto po sabi nila per item
    Class A (Needs Immediate Replacement/Safety Related)
    1. Oil Pan Gasket
    2. Crankshaft oil seal frt
    3. Camshaft oil seal fr
    4. Oil pump o-ring
    5. Crankshaft oil seal rr
    6. Nee to overhaul P.S Pump
    Sabi po sa akin from number 1-4 is 7k then yung number 5 is 5k and 6 is 5k as well.
    Ask ko lang sana if etong price na to is reasonable or ok lang sa iba ko to pagawa na mas less sa price? (Medyo tight sa budget)
    Thanks po sa lahat ng sasagot
    Sep 2004
    Something's wrong with the quotation. Over 17k?? (7k + 5k + 5k)
    Yung number 5 (crankshaft oil seal, right rear) is worth 5k?? Jeez, oil seal lang yun!
    To compare, I bought 2 timing belts, a set of oil seals and an oil pan gasket for my 97 Accord sa Honda Quezon Ave. Mga 6.6k lang ang damage.
    I suggest you get a quotation from a different casa. Taga masyado sa Shaw. Tapos paayos sa Speedyfix and look for Migs (malapit lang sila sa Honda Shaw). Search mo na lang dito for his exact address.
    Thanks po sa feedback. Nakita ko nga po yung SpeedyFix bale dun na rin po ba sa kanila yung parts if ever dun ko pagawa?
    Sep 2005
    sir...ung oil seals mo sa casa mo kunin kci sa experience ko sa labas ako kumuha eh tumulo agad. papalit mo na ring T-belt kung 2nd hand mo na nakuha para sure ka na hindi ka ibibitin sa biyahe.
    Aug 2006
    Quote Originally Posted by majorguile View Post
    Get a quotation from SpeedyFix and compare the parts and scope of work. Base from my observation, I see not just Honda cars but also BMW's being fixed there so maybe they know how to source original parts.
    I only go to SpeedyFix for change oil since my car is still new.
    super mahal naman,eh puro seals kang yan....sa labas mo na lang pagawa malaki pa matitipid mo, pwede mo pa kami malibre
    If you're near Honda Shaw, +1 to get an estimate from Speedyfix. They can get replacement parts with a little premium pricing lang nga (when I compare prices with auto supply stores after). Oks lang rin, at least less hassle to get the parts yourself.
    Else, another option, reco try Honda Q. Ave. - from experience, better orig parts pricing, and repair competence. It may not be perfect, but they showed better competence than Honda Shaw for us.
Oil Leak Quotation
