Page 1 of 3 123 LastLast
Results 1 to 20 of 86
    Aug 2010
    Any inputs on this? My current ride is a Vios and in some forums they recommend the use of this oil in gasoline engines because of its cleaning properties.
    I gave it a try and my engine seems to be responding well despite it being originally advertised for diesel engines. My filter is Union brand. I plan to change oil after 1000 kms with Delo Gold Ultra again paired with Baldwin oil filter then change oil after 5000kms. After that, still deliberating whether I will switch to synthetic oil or continue with this regime. But I want to know everyone's opinion on this change oil regime. Thanks.
    Jun 2010
    delo gold ultra is ch-4 sj rated and is designed for fleet aplication kaya pwede for gas or diesel, delo gold multi-grade din ang gamit ko sa civic at feroza ko for 2 consecutive oil change na wala namang problema mas mura pa.
    Sep 2013
    Quote Originally Posted by raycon_24 View Post
    Delo gold is CH-4. Delo gold ultra is CI-4. Delo 400 is CI-4+.
    Jul 2011
    magkano ang 4L ng DGU?
    Sent from my GT-N7100 using Tapatalk 4
    Aug 2010
    I bought mine sa caltex station less than php1000.
    Oct 2011
    Quote Originally Posted by s10pao View Post
    Price should be around 200 petot.
    Jul 2011
    boss na try mo na DGU at Zic A?
    Oct 2011
    dehins pa sir. mobil delvac mx pa lang.
    Aug 2013
    Alin maganda sa Caltex DGU at Mobil Delvac MX with respect to price and properties that meets gas engine application?
    Dec 2013
    magkano po ba ang baldwin oil filter na pang toyota 2E? thanks!
    231 pesos per liter sa gas station, it might be even cheaper sa auto shops...
    Aug 2010
    Yun nga rin po sir ang naresearch ko about this oil. It's a 15W 40 multigrade oil and it's cat con friendly. Ang sabi lang is follow 5k change oil kasi masmakapit daw sa loob ng makina kapag napabayaan magsludge.
    May 2012
    Naka promo din ba ang delo gold ultra? Na ask ko kasi sa isang auto supply may promo daw ang delo but ang available nila is yung delo gold lang. Parang 765 pesos yata for 5 liters na.
    Sent from my iPod touch using Tapatalk - now Free
    Sep 2013
    1200 or 1400ppm ba ang safe zddp level?
    Aug 2013
    Quote Originally Posted by chookchakchenes View Post
    1200 ppm zddp and below ang safe level for gasoline engines
    Jul 2011
    depende pa rin ata sa API rating na recommended sa engine mo. pag SN and above 800ppm ang limit ata.
    So pwede yung Mobil Delvac MX sa gas?
    Yes. just go over the API ratings. If the oil has a API gas rating (ex. SL, SM, SN) then it can be used on gas engines just as well.
    Oct 2011
    Afaik pwede yan sir mas maganda pa nga kasi mas maraming detergents.
    Sent from my iPad using Tsikot Car Forums
    Thanks sir bilis mo sumagot, pinost ko tanong eh nasa Ace hardware na ko, bago nakalabas nabasa ko reply mo, hehe.
    Kanina pa ko naghahanap ng DGU sa mga caltex hirap pala hanapin nun.
Caltex Delo Gold Ultra
