Results 1 to 20 of 29
    naeexperience ko to kapag tinotodo or at least near floor na ung gas pedal, as in parang napuputol ung daloy or nagpupugak pugak ung takbo nya. Pede kayang Spark Plug ang culprit?
    Ano Sasakyan mo bro? EFI ba o Carburated?
    Quote Originally Posted by eatmylens View Post
    It would help us to help you if you would mention what car and year/model you have and what recent work was done to it as well.
    what fuel you are using?
    Jul 2010
    eto mahirap broGH, gusto nating mag-comment o mag-advice pero we are at lost, di sinasabi kumpletong specs ng sasakyan ng mga humihingi ng advice...
    BroTS, balik ka dito oy....
    kailan ka huling nagpalit ng fuel filter?
    baka kasi kailangan na palitan o barado na.
    double post.
    (bumabagsak ang tsikot dito sa pc ko kasi.)
    Dec 2010
    you may try checking your distributor alignment (if applicable) and the condition of your spark plugs as well.
    Ay sorry po, nakalimutan kong ilagay yung vehicle information. Anyway, it's a Toyota Corolla AE92 (Small body, 89mdl[?]) 4A-F/Carb. Sa Kuya ko kasi to medyo napabayaan na kasi nasa abroad na sya ngayon, kaya ako ung unti-onting nagpapa-ayos. I believe wala syang ginawang modifications sa engine lahat aesthetic mods lang.
    Salamat po sa mga replies and info's given. Will definitely have a mechanic check its Fuel Filter and Distribution alignment. Regarding the fuel I'm using, I use a premium (Shell/Petron)
    To be more specific regarding the "Pugak", ung bang parang my "papigil-pigil" sa buong koche na tipong mapapa-lean forward ka. Hindi sya ung tipo na parang tuloy tuloy parin ung takbo na parang nilagay mo lang sa neutral.
    Additional info: Na-e-experience ko lang to kapag on "Gear" especially kapag nasa segunda (Or,at least mas madalas mangyari kapag naka segunda) kasi kahit i-todo rev ko ng naka neutral(Stationary) okay naman, kahit i-floor pa ung gas pedal.
    Check your carb and your carb jets. Shell and Petron fuels are E10 blended gasolines (except for Petron Blaze). Ethanol and carbs do not mix well and tends to damage the jets over time by erosion of the tip. Give it enough time, it affects the way the engine runs, causing over-rich mixtures.
Parang nabubulunan kapag tinotodo ung gas pedal
