Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Feb 2014
    Quote Originally Posted by raycon_24 View Post
    same problem ng nissan ng kumpare ko, pa check mo yung fuel pump filter/screen baka barado, tangalin nyo muna yung filter then test drive kung may improvement.
    Ahh talaga? Hindi ba pag barado un, wala ng papasok na gas? Or meron pa din kaya lang hirap na pumasok kaya aalog makina? Yun ba ung kailangan electrician sir?
    Oct 2009
    binuksan mo naba ung distributor cap.baka naman puro tutong na ng umido ung mga paa.
    try mo din ipa timing lights.
    Oct 2014
    Anyone experienced the same. I have hyundai tucson 09model AT trans
    Noticed engine rpm at start up close to a thousand and that engine sounds is accelerating.
    Observed it as well in one instance where engine continue revving up even if brake is fully applied.
    What could be the cause on this one?
    Thanks for your help.
    May 2004
    Quote Originally Posted by Buh View Post
    Hi. I'm new here.
    Kailangan lang ng tulong. Yung kotse ko kasi hirap humatak at mag accelerate. Nissan Sentra 98 model sya. 108k kms na. Binili namin sya ng brand new.
    So mga 2-3 months ago, pinapaltan ko ung spark plugs nya. Medyo umokay naman yung takbo. Sabi lang nung mekaniko, kung may reklamo pa din ako, palinis na yung cervo at yung fuel injectors. So mga last month, pinalinis ko ung cervo. Kasi nga, mahina pa din humatak. Nag improve naman sya ng ilang linggo. But last week, pinalinis ko naman ung fuel injectors. Pero ayun, medyo mahina pa din at pansin na pansin sa highway (commonwealth, edsa). Lalo na sa mga flyovers.
    Okay naman sya sa 4th-5th gear. Keeping it at 60km/h, pero kaya pa nya tumakbo ng mas mabilis.
    Tapos, madalas din sya umalog. Pag nag shift ako ng gear, aalog sya pag wala sa timing.
    So, anu kaya pwede ko pa ayos, patingnan or papaltan ulit? Balak ko kasi pumunta ng Banawe, gusto ko lang ng mga tips or suggestions galing dito.
    Thanks!
    Try mo lang ito sir...
    since injected na yung sentra nyo (and presumably ECCS engine yan), try to bring it to a gas station na may diagnostic tool.
    It will save you time and all the guesswork kung ano yng sira.
    HTH
    did i mention slipping clutch disk?
    Feb 2014
    Quote Originally Posted by boy astig View Post
    HTH
    Hi! Thanks! Subukan ko yan ha. Para saan pala yung diagnostic tool? Anu sasabihin ko?
    I've noticed too na pag malamig ung makina, hirap syang mag start. Pero tutuloy naman ung pag start, hirap lang talaga.
    Feb 2014
    Not yet sir, I'll put that in mind. Thanks!
Trouble Accelerating
