Results 1 to 2 of 2
    Is it hard to replace the timing belt on Toyota 2E engine. I think, compared to other engine, i just have to remove the fan belt, and timing belt cover, put markers on the gears and make sure it'll not move when i replace the new belt. That's how i picture it, or is it much more complicated than that?
    well if your a good basic machanic i thinks its easy enough if you know you way around the engine ..... 2e is the easiest toyota engine ... but if your not sure ask a mechanic ....
    try changing your tensioner para isang palitan nalang ...
    usually the labor of 2e enigine is about 650 ... if i am not mistaken
    BANAWE AUTO SUPPLY
    7120115
    regy
Change timing belt on toyota 2E
