Results 1 to 6 of 6
- 25
May 15th, 2010 01:44 PM #1Guys share ko lang experience ko sa oto ko,
I got this car since college a toyota corolla xe big body..
Pag hindi ako nka aircon ok ang takbo "smooth", but pag ON ko na A/C prang hirap na sya umarangkada..
what should i do?
ano kya problema nito?
May 15th, 2010 02:59 PM #3
perhaps it is oil starved? just recently, I learn from an expert here about the freon/oil ratio. it seems my a/c technician is oil starving our compressors for more than 50% it really needs.
- 25
May 15th, 2010 08:39 PM #5Cguro pa check ko na nga A/C as well as compresor..
*ghosthunter
Bearing saan?
May 15th, 2010 09:34 PM #6
Two places where the bearings could have started to fail:
-tensioner pulleys
-shaft bearings on the compressor itself
BTW, if someone did any work recently in the general area like replace a fan belt to the a/c compressor, it could also be an overtightened/over-tensioned fan belt.Last edited by ghosthunter; May 15th, 2010 at 09:37 PM.
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
