sir thanks for the informative response!
all suspensions parts are bnew ( tie rod, rack end, ball joints, bushings, and stabilizers )
and the new set of tires. the shop doesnt have a wheel alignment. so probably this vibration causes the problem at 120kmh. I Havent Floor the Gas pedal yet. i think it can go more than 120 but when this vibration occurs (at 110 - 120kmh) Im afraid to floor the gas pedal because the vibration increases eh. ramdam ko sa steering wheel yun nasa SCTEX ako.
siguro Ill have wheel alignment muna? then after that pag nawala yun Ill try to hit it more than 120.
yes there is overdrive button. ginagamit ko ito sa overtaking. sige ill try it
