Results 1 to 10 of 10
    Feb 2012
    For the last two mornings (with car having been parked up all night) I have had a
    bit of a delay with the engine starting up after turning the key, it takes about 2 to 3
    seconds before the car actually cranks...
    What would be the culprit for this?
    Battery dying?
    Feb 2012
    Medyo bago pa battery ko, mag 1 year pa lng sir..
    Check the battery connections. Baka maluwag or madumi. Kung ganun pa din check starter baka kelangan cleaning.
    nag install ka ba ng after market alarm?
    Jun 2006
    Starter crabon brushes could be running thin.
    May 2010
    Quote Originally Posted by robot.sonic View Post
    Sir, Im also experiencing the same with TS and I also have an after market alarm installed in my ride. Is there any effect installing an alarm with the said issue?
    Feb 2009
    Quote Originally Posted by aZzip View Post
    as an S.O.P., please identify the vehicle so others with the same vehicle are made aware or share the possible same symptoms and share the same remedy. if the car is of age, you might want to lubricate the ignition lock cylinder and maybe the associated ignition switch attached to it. provide more information about your car and the symptoms
    Ganyan din problem ko dati. Pinatanggal ko na lang yung cut off.
    Sent from my Nexus 7 using Tapatalk HD
Slight delay when starting
