Results 1 to 10 of 10
- Feb 2012
- 31
April 29th, 2013 12:18 PM #1For the last two mornings (with car having been parked up all night) I have had a
bit of a delay with the engine starting up after turning the key, it takes about 2 to 3
seconds before the car actually cranks...
What would be the culprit for this?
- Feb 2012
- 31
April 29th, 2013 12:54 PM #4
Check the battery connections. Baka maluwag or madumi. Kung ganun pa din check starter baka kelangan cleaning.
- Jun 2006
- 1,139
- Feb 2012
- 31
April 29th, 2013 02:32 PM #7* robot.sonic.. yes sir meron ako aftermarket alarm.
*shibby75.. sir any idea kung magkano magpaclean/repair ng starter?
May 2nd, 2013 11:47 AM #8
May 2nd, 2013 01:12 PM #9
as an S.O.P., please identify the vehicle so others with the same vehicle are made aware or share the possible same symptoms and share the same remedy. if the car is of age, you might want to lubricate the ignition lock cylinder and maybe the associated ignition switch attached to it. provide more information about your car and the symptoms
May 2nd, 2013 01:24 PM #10
Ganyan din problem ko dati. Pinatanggal ko na lang yung cut off.
Sent from my Nexus 7 using Tapatalk HD
i confess, my seagull review is from internet literature. that so-called aircon issue is a...
BYD Seagull
