Results 1 to 13 of 13
    Yung tsikot ko na honda lxi 1996, kapag nirerev eh prang my hika, kumbaga parang taong may asthma na kinakapos yung hininga. Tapos mahina din humatak. ano kaya problem nun?.... TIA
    start with the basics, complete tune-up. change fuel filter.
    Jun 2009
    tama po yung tune up po muna
    1 change spark plugs
    2 change air filter
    3 change fuel filter
    4 change oil filter
    5 change engine oil
    kung na aadjust din ang valve clearance at timing ng lxi ipa-adjust mo na rin
    May 2007
    Quote Originally Posted by ramledi View Post
    2 change air filter
    4 change oil filter
    5 change engine oil
    Or...change the car.
    Quote Originally Posted by v6dreamer View Post
    Wala pang pang palit eh. heheh
    Pina tune up ko na kasi yan weeks ago, tapos pinapalitan ko yung oil seal, sa crank tsaka sa taas(ano ulit twag dun?) kaya kinalas yung engine kasama yung timing belt, palagay ko hindi maganda pagkakabalik nung timing belt. o mali yung timing? pwede bang yun yung reason kaya humina hatak?
    mali ang timing nyan bro.. what you can also do is to reset the ECU first and observe the results since kakapa tune up mo lang pala.
    Sir can you recommend a shop that can do complete tune up?
    Location ko po is commonwealth Q.C.
    Saan po ba ma recommend nyo? Thanks in advance.
    And how much nga po pala usually and complete tune up?
Parang may hika makina, tapos mahina hatak
