Results 1 to 19 of 19
    Apr 2014
    Both are semi-synthetic engine oils for gasoline ..
    Which is better for my Corolla GLi 4afe ???
    Apr 2012
    Quote Originally Posted by Dezaremos View Post
    Get the 10W40
    Sent from my SM-J730G using Tapatalk
    Get the 10W40
    +1
    Jan 2016
    magkano yung Caltex 5w30?
    If looking for a semi-synthetic blend, I would suggest Shell Helix HX7 5w40. I got it before for around P250 per liter.
    I have also used Valvoline NextGen 10w40 and it was even cheaper at 1200 for a 5-quart container (Ace Hardware).
    these are solid facts 👍
    Apr 2014
    Both are almost the same price ..
    Apr 2014
    Get the 10W40
    They say the only reason not to use synthetic or semi-synthetic in an old engine because it might leak due to old seals .. but my 4afe oil seals are new, camshaft seal, sparkplug seal, etc ..
    Hindi ba rin pwede mag synthetic ?? Hindi ba pwede sa engine ko ang masyadong manipis like 5w30 ?? How about 5w40 ??
    Apr 2012
    5w40/ 10w40 would be fine.
    I'd stick with semi synth pa din every 5k kms palit. Lalo pag medyo ma edad na engine needs tlc
    Sep 2014
    OT. ok din ba ang Mobil super 1000 15W40?
    Sent from my SM-G920F using Tapatalk
    Quote Originally Posted by grand kotse View Post
    It will be a bit thick in viscosity against products of the same price, unless you have a very old gas engine. You better go with Shell Helix HX7 5w40 or Zic X7 10w40.
    Sep 2014
    thanks
    5w40 will be just fine
    Apr 2014
    But 5w30 is not good ??
    If your car’s engine requires it, then use it. I use 5w30 fully synthetic on my turbo cars.
    Mar 2018
    For an older engine, better use the 10w-40 than the 5w-30. The higher viscosity oil (i.e. 10w-40) has better film strength for hot ambient temperatures like ours.
    sometimes, the specification for thinner oil has to do with its better ability to squeeze itself into the minute oil passages of the engine, compared to heavier oils.
    ever heard of cooling systems?
    FOCUS
Mobil Super 2000 10w40 semi-synth vs Caltex 5w30 Synth-Blend
