Results 1 to 17 of 17
    Apr 2009
    Nagawa ko na po kasi ito once, when I tried to help a friend whose battery was drained!
    So I started my car, and removed the battery (to start hers) and the engine kept running.
    It worked well without problem, pero I don't get the principle behind it!
    I used to think na kasi once the engine is running, yung alternator na yung nag-susupply ng voltage sa ignition coil (so on).
    But I'm not convinced and it still is a mystery to me.
    Can someone please englighten this?
    Thanks
    You are correct. Because the battery is a storage device. But once started, the alternator can make enough juice to keep the car running. About the only things that won't work are those things directly wired to your battery (e.g. amplifiers, upgraded horns, etc.).
    +1, did this as well before. But better use a jump start cable na lang sana.
    Jun 2006
    Pwede ba yan sa gas engine? Akala ko sa diesel lang pwede ito.
    Pwede naman sa gas. Did it to an Accord. Emergency kasi and I didn't have my gear with me.
    Apr 2009
    totoo ba na masisira yung IC ng alternator pag matagal na pinaandar na walang battery?
    Apr 2009
    Quote Originally Posted by JJGF View Post
    Ano po yung IC?
    May 2009
    Quote Originally Posted by userfriendly View Post
    pwede sa mga purely mechanical diesels....mga walang solenoid valve sa injection pump...4ba1, c-190 and so on....
    both gas and diesel, pwede...
    the only problem is you might blew the vehicles' electronic parts like ecu... likewise, the IC or the regulator inside the alternator will be in danger too...
    Jun 2010
    Quote Originally Posted by phezthie View Post
    +10 to paps phezthie
    eto din advise sakin ng mekaniko... this can be done once in a blue moon to diagnose the integrity of alternator if its failing or not... running the car without a battery especially for longer hours is a big no-no it will fry your circuitry
    Apr 2009
    Wala po kaming pang-jumpstart eh hindi na din po namin nakuha sa tulak kasi ayaw talaga dahil wala ng crank.
    Yep, wala po akong sounds and horns nun!
    Pero buti gumana yung lights.
    Thanks for the inputs!
Running car without battery after starting
