Results 1 to 10 of 15
July 14th, 2014 03:30 AM #1
Mazda 3 2005 1.6l.
patulong naman po regarding my car. start up rpm is normal, pag nareach na normal operating temp. ng vehicle rpm fluctuates (w/ load gear in D and a/c on) pero hindi siya namamatay. pag walang load (gear in N & a/c off) rpm surges to more or less 2000. if you try to rev the engine to about 3k to 4k the rpm goes down but not below 2500. if you try to rev up to 6k and release the accelerator pedal it goes down to normal idling (but not always), otherwise rpm fluctuates again. I've already changed MAF sensor, IAC valve, and already cleaned throttle body but the problem still persist. patulong naman po, ayaw kung dalhin sa dealer kasi diagnosing pa lang mahal na...
July 14th, 2014 09:29 AM #2
Since nagawa mo na yung basics... Next thing to do is have it scanned ng obd scanner para malaman kung may iba pang problem.
Sent from my Windows Phone 8 using Tapatalk
- Jul 2014
- 162
July 15th, 2014 12:31 AM #5
- Jul 2014
- 162
July 15th, 2014 12:49 AM #7Dami pwede pgmulan ng trouble bro... Pero try mo hugutin socket wire ng TPsensor kung di ka nka TAC motor ang throttle body mo.. Jn mo malalaman kung mg stable sya ng idling... Pwede din ung socket ng MAF bunutin mo malalaman mo din kung mg stable din ang engine. Kc pwede sa CMP,ECT o mechanical gaya ng leak ang gasket mo... Sa gear pwede sa TCC... Sana di sa PCM kc kadalasan ang makina ng Mazda at ford jn ang problema..
July 15th, 2014 06:34 AM #8
thanks mrjeff...try ko yung throttle position sensor, yung mass air flow sensor bagong palit lang yun eh. hopefully basic lang problem nito.🚘 wala pa din kasi ako time magpascan kung may stored faults ang ecu, sa weekend pag maisingit.
Posted via Tsikot Mobile App
- Jul 2014
- 162
- Jun 2011
- 130
July 15th, 2014 11:18 AM #10Huwag ka munang palit ng palit ng electrical parts hanggat di na scan, malalakihan ka dyan. Makikita naman yan sa scan kung electrical parts ang may problema. Pero ang leak, fuel presure regulator at fuel filter di makikita sa scan kaya check mo muna ito.
Planning to buy a second car. Help me choose. Honda accord has 71k mileage for ₱465,000 Nissan...
honda accord 2014 2.4L vs nissan altima 2015
