Results 1 to 10 of 24
    Feb 2009
    i hate to cross the bridge before i get in front of it, but the most common fault of this symptom is a bad tps. your tps has three terminals. check continuity/resistance between the top and the bottom terminals. if the resistance is infinite, it's time to replace it. if there is continuity and less than infinite resistance, do a sweep between the middle and either top or bottom terminal of the sensor. if at somewhere about 40% throttle opening you find a glitch, the tps is bad. try running the engine at around a threshold of 2000 rpm, this is the most common engine speed when the engine "hunts" if the tps is faulty
    Jun 2011
    check also for vacuum leaks and clean IACV
RPM fluctuation when on complete stop
