I'm just wondering... same engine make, same displacement, normally aspirated, but different power/torque characteristics. How do they differ in acceleration performance? It's almost as same as the HP vs Torque question, but how come the end result is somewhat hard to predict(lets add gear ratios as a variable here)?
or
Lets say we compare an american muscle V8 engine vs. honda NA engines (S2000 or NSX engine), with the same HP. What do you think which will have a better result on straight line speed / cornering?
Usually Honda's engine are naturally high-revving while pushrod large-displacement musclecar engines do have lots of torque. Can the honda engine keep up with a musclecar engine because it can rev higher while engaged on a lower gear ratio before hitting the rev limit then shift, or the musclecar engine would just outrun the honda engine because of sheer torque numbers?
And sa NFS:U2 or kahit sa GT... dyno charts there tells that maximum torque usually peaks just right before maximum power is achieved. In the real world, how does that translate to acceleration? Why not shift up on the moment the torque peaks instead of waiting for the engine to hit the rev limit?
