Results 1 to 7 of 7
    Feb 2006
    mga bossing question lang..
    paano ko po ba malalaman kung pundido/palyado ang sparkplug ko..??
    ano po ang pwede kong i-test?
    maraming salamat po..!
    Quote Originally Posted by carlo21 View Post
    i don't know if it can be tested using a voltage tester... hehehe.
    but a surefire way to test it is to replace it. in fact, replace all of it. mura lang naman spark plugs ngayon, specially if you are using the stock ones.
    May 2007
    kapag may pundidong spark plug rough ang andar ng makina at ang pwede mong gawin, medyo ingat lang kasi masakit din ang hi-voltage, ay ganito:
    1. pull-out one hi-tension wire at a time, kung ok ang spark plug lalong lala ang roughness baka mamatay pa makina. if you chance upon a spark plug na walang changes kahit binunot mo na hi-tensio wire yun ang pundido.
    2. to make sure, pagpalitin mo ang spark plugs. kapag lumipat ang walang "changes" then you are sure na sira ang spark plug.
    3. if so happen na even if you have change places yung spark plugs at yung "no changes" di lumipat, baka yung hi-tension wire ang may problema o baka corroded lang ang contacts. linis lang katapat nun.
    Feb 2006
    *1D4LV
    sayang kasi sir halos 1 month pa lang..
    *eyshmechanic
    thank you po try ko po yan..
    1,ang tinutukoy mo po bang roughness ay ung alog/idle ng oto..
    2,tapos pag binunot ko ba ung HTW pwede ko rin ba sya ibalik kahit naka ON pa ang makina/kotse?
    sorry for ignorant question...thanks
    May 2007
    *1D4LV
    *eyshmechanic
    1. yup
    2. yup again, pwede bunot - saksak (he he) para mas maramdaman ang difference kung nakakabit at hindi.
    Apr 2008
    *1D4LV
    *eyshmechanic
    its called power balance test,wear insulated gloves, abot sa pusod ang koryente nyan,22,000 volts,pulse nga lang,d nakakamatay.sa una lang nakakatakot yan.
    Nov 2003
    you will know agad naman because of the vibration na sira yung plug.
pundidong sparkplug..help!!
