Results 1 to 10 of 11
- Dec 2009
- 47
July 19th, 2010 11:09 AM #1
nag changeoil ako ng 4d56t ko then after few days pag open ko ng oil cap ko umuusok then hinatak ko ang dipstick meron din...kaka pa top overhaul ko lang kase may crank sa likod yun head ko... usok pa din oil cap at dipstick hindi naman po ako nag ooverheat same pa din takbo ng engine ko na pag pumalo ng 80kph hirap na hirap na siya
any idea ano mga possible sira? overhaul naba? magkano kaya ito aabutin or better change the engine!?
- Aug 2003
- 9,720
July 19th, 2010 11:45 AM #3
it's called blow by, common na sakit ng 4d56tdic
solution jan general overhaul. kalokohan yung top overhaul kasi kadalasan hindi nakukuha.
kung di ka naman maarte, ok lang yan, pwede mo gamitin.
- Dec 2009
- 47
July 19th, 2010 12:08 PM #42nd hand ko po ito nabili nung hindi pa ako nag change oil ok na ok pa
nag top overhaul po ako kase may crack yun head niya
wala naba iba cause nito? sure ba na overhaul kahit hindi ako nag babawas ng oil?
enge naman ng price magkano ito aabutin hays gatos
July 19th, 2010 04:00 PM #5
sana sir nung tinop overhaul pinacheck mo na din yung mga piston ring kung okay pa?
para saken hmm dala na ako sa overhaul eh change engine na lang sir? mga 40k
July 19th, 2010 04:02 PM #6
Sir:
You may want to read an old post of mine on the thread:
"one cylinder is dead"
http://tsikot.yehey.com/forums/showp...9&postcount=11
Sincerely,
Dusky Lim
- Dec 2009
- 47
July 20th, 2010 03:14 AM #7
- Dec 2009
- 47
July 20th, 2010 03:30 AM #8
July 20th, 2010 08:51 AM #9
hmmmm compresion test mo muna pero btw tapos na ba ang break in period nya ? or ilan na ba natatakbo nya simula nung na top overhaul sya?
- Dec 2009
- 47
July 20th, 2010 01:26 PM #10
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
