Results 1 to 9 of 9
- Dec 2005
- 8
June 1st, 2006 06:25 PM #1[[FONT=Lucida Sans Unicode]FONT=Lucida Sans Unicode]i got 95 civic esi. a/t. before hirap ung makina humatak minsan tumataas p un temp.until H. pina tgnan me s mechanic. he adjust the timing thru distributor and check it with Timing light aparatus. ok n un takbo nya ngyon smooth n un hatak...but when u start the engine at P gear hinde n nagstart u have to shift s N. saka p lng start. before un n timing kahit s P gear one click lng start n. ngyon namamatay cya. ano kaya mali dun s timing?
tnx po.
June 2nd, 2006 11:55 AM #2
huh? alam ko di mag-start yun sa N eh. sa P siya mag-start. kung tumataas ang temp mo. baka masira ang makina.
OT: anong cause bakit humihina ang hatak ng makina?
- Dec 2005
- 8
June 3rd, 2006 11:45 AM #3hind en tumataas un temp ngayon. sabi ng mechanic eh nde daw naka timing kaya hirap humatak makina.
June 3rd, 2006 03:25 PM #4
Engine won't crank
Steps:
1. Generally caused by either a dead battery or a bad starter, although you should check steps 1 through 5 to make sure it's not an operator error.
2. If car is automatic, check that transmission is in park and your foot is on brake.
3. If car is stick shift, check that clutch pedal is fully depressed. Check neutral safety switch behind clutch pedal (small button that prevents engine from starting when transmission is in gear). If clutch pedal doesn't fully engage neutral safety switch, engine will not crank.
4. Check that driver's seat belt is fastened (some cars will not start with seat belt unlatched).
5. Make sure you've properly inserted key. Turn it to On position and give steering wheel quarter turn in either direction.
6. Make sure alarm system is not activated, preventing car from starting.
7. Check for dead battery. Test wipers, radio, headlights and heater fan. If all work normally, battery is probably charged and you may have bad starter. If they don't work, move on to next step.
8. Check connection at battery and at starter .If battery connections are good and all accessories work, consider jumpstarting car .
9. Open hood and check battery connections at terminals. If either connector is loose enough to move, problem may be bad connection. Jiggle or tighten cable end. Corrosion at battery terminal will also prevent car from starting. Clean terminal with wire brush or water and rag and tighten battery cable connectors.
10. Check connection at starter. Follow battery cable from positive battery terminal to starter. Make sure connection isn't loose. Lightly tap outside of starter with hammer. Sometimes this will free stuck components inside so car can start.
11. Consider push-starting car (manual transmission only) if battery or starter is at fault .
12. Call tow truck.
Toyota is my choice
- Aug 2005
- 2,063
June 4th, 2006 04:56 AM #6
Originally Posted by kabuke0
- some cars wont start, if your not stepping on clutch pedal
- check battery terminal if theres some corrosion
- Fuse Box (fuse maybe busted)
June 4th, 2006 07:47 PM #8
Originally Posted by entoy
1. Pag-start mo sa "N", ok at walang problema (puwedeng puwede gamitin ang kotse)?
2. Pag-start mo sa "P" na ayaw magstart. Paki-describe kung alin sa tatlo.
a. Nagstart yung makina saglit tapos namamatay agad?
b. Nagreredondo lang yung makina (naririnig yung starter)?
c. Walang nangyayari talaga (yung kagaya nung kung subukan mo magstart sa "D" or "R")?
3. Pag na-start mo na sa "N", tapos mag shift ka sa "P" namamatay pa ba yung makina?Last edited by Autobeat; June 4th, 2006 at 07:50 PM.
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
