Results 1 to 13 of 13
    Sep 2014
    The picture shows the diesel engine of my Innova 2.5G
    There is a layer of black, oily grunge accumulated around the small rubber hose near the pcv and on the underside of the large rubber hose.
    When the grunge is removed, I can find a small amount of light yellowish oil accumulated around of the joint of the pcv and the small hose after the car has been used for one or two days.
    Is this normal in diesel engine as the Toyota technician told me?
    Please answer in English.
    Oct 2015
    I also have that same leak.
    Was also told by toyota that it was normal.
    Sep 2014
    I have no idea when the oil leak began to occur.
    My car is only 2 years old and is maintained by Toyota.
    If the leak is inevitable, manufacturer should have installed a device to catch the oil and not let it be seen by the user.
    Quote Originally Posted by bigT View Post
    an auto "expert" said years ago, that the use of these scrawny, wire hose clamps, three of which are shown in the picture (two large ones, one small one), was intended primarily for assembly purposes . he recommended to have these "clamps" replaced by the more effective hose clamps that we can easily source from auto parts stores.
    my guess is, your problem will disappear when you replace this one, sir.
    btw, my innova's is dirtier than yours. and i haven't replaced the clamp, either. guilty... guilty... heh heh.
    Apr 2010
    Kind of similar to my post: At around 1500KMs, napansin ko there is an oily hose coming to the air filter housing
    I believe this is the PCV and should be solved by an oil catch can/tank... I myself do not have one installed yet, naghahanap pa ako ng can with (almost)similar size fittings
    Jul 2013
    A friend of mine who is not from Toyota said it is normal. You cannot totally eliminate oil from escaping the engine together with the blow-by gases.
    Install an oil catch can if you wish not to see oil leaks from that part.
    Oct 2009
    gaya ng sinabi ni dr.D
    palitan nyo nalang ng ordinary clamps mura lang yan sa auto supply.ung malapad un na may mga gilit gilit .nagsisismula na kasi lumambot ung rubber hose mo dahil sa oil.kaya mas maganda kung palitan mo ng ibang clamps ung siguradong mayayakap niyang mabuti ung hose.
    yan yata ung clamp na pwede mong pigain lang ng daliri mo matatanggal mo na.
    Apr 2010
    I experience the same behavior at only 1500 on the odo, and noticed the same on another 2KD engine with less than 10,000KMs so hindi siya sa clamps lang.
Oily grunge in diesel engine
