Results 1 to 8 of 8
    Apr 2010
    Hi guys,
    could you recommend me a good shop for cleaning my Mass air flow, Fuel Injector cleaning or possibly fuel filter? medyo mahina na batak ng Rav4 Gen 2 Automatic 4x4 ko. paki post na rin kung saan location and how much yun labor nila?
    additional details nun rav4 ko eh wont past over 2000 rpm while driving. parang hindi yata makahinga? pero so far ok naman yun takbo.
    thanks.
    Sep 2006
    Quote Originally Posted by kicks4us24 View Post
    Hi guys,
    thanks.
    Did you have your Rav4 scanned for faults? How did you conclude that your mass air flow sensor and injectors require cleaning?
    Apr 2010
    well, I can see my rpm tach wont go more than 2000rpm. but i really not sure of that.
    and heres another thing I observed yesterday
    just have a trip to tagaytay (exit ko yun santa rosa) yesterday, while i was driving at slex, my rav cant go more than 60 km/h but can go as much as 80km/h with a HARD long step on accelerator pedal on the floor. I can here the engine rpm rises at yun racing sound talaga galing sa engine pero di tumataas more than 80 km/h. parang kaunti lang ang ibinibilis mula 60 km/h
    specs ng rav4 ko.
    -1AZ-FE
    -4x4 AWD
    -Gen 2 2001
    -Automatic transmission
    -43333 km na natakbo
    ano ba problem nito guys? sorry for my ignorance but may clutch ba AT tranny? lalo na yun road papunta sa tagaytay na di naman masyado steep yun daan. in short "hirap sa hatak" kahit minor uphill lang. (cruising at 40 to 50 km/h yun na sagad) I can hear the engine response and rpm rises but I cant overtake na or ayaw pa bumilis more than 40km/h.
    i dont know kung ano culprit nito.
    already changed new engine oil, new fuel filter and new AT fluid for regular maintenance.
    still ganun pa din.. hirap na hatak nya. di na masyado maka overtake.
    I think this is more of a problem than my rpm wont rise over 2000rpm.
    patulong po. thanks.
    Sep 2006
    well, I can see my rpm tach wont go more than 2000rpm. but i really not sure of that. Your tach may be giving out wrong readings.
    and heres another thing I observed yesterday. just have a trip to tagaytay (exit ko yun santa rosa) yesterday, while i was driving at slex, my rav cant go more than 60 km/h but can go as much as 80km/h with a HARD long step on accelerator pedal on the floor. I can here the engine rpm rises at yun racing sound talaga galing sa engine pero di tumataas more than 80 km/h. parang kaunti lang ang ibinibilis mula 60 km/h Baka dumudulas ang auto transmission.
    specs ng rav4 ko.
    -1AZ-FE
    -4x4 AWD
    -Gen 2 2001
    ano ba problem nito guys? sorry for my ignorance but may clutch ba AT tranny? Meron.
    lalo na yun road papunta sa tagaytay na di naman masyado steep yun daan. in short "hirap sa hatak" kahit minor uphill lang. (cruising at 40 to 50 km/h yun na sagad) I can hear the engine response and rpm rises but I cant overtake na or ayaw pa bumilis more than 40km/h. i dont know kung ano culprit nito. Sliding tranny clutch.
    already changed new engine oil, new fuel filter and new AT fluid for regular maintenance. still ganun pa din.. hirap na hatak nya. di na masyado maka overtake. Sunog ba yung AT fluid during your last oil change? This is a sign of sliding clutch.
    patulong po. thanks. All you have to do is bring your car to Toyota and seek their advise. Libre yan. Kung scanning, meron konti charges.
    up ko lang mga sir... may solution ka na ba dito? experiencing the same with my 1st gen rav4.
    http://tsikot.com/forums/honda-cars-...-em-yet-82540/
    Never tried their service before pero may 3 forumers dyan na nagsasabi na maganda daw. Balitaan nyo na lang kami.
    thanks robot.sonic! daanan ko ito next week, kapit bahay ko lang eh :D
    Feb 2009
    your engine is probably suffering from loss of power. take care of the engine first, then the transmission. if the engine is not performing well, even if you install a brand new transmission, it still can not go at normal speeds. check the obvious first. check your exhaust if it is plugged, check your ignition, if the voltage is not delivered properly at the plugs or the spark plugs are fouled you still will not get power output. also, don't forget to check the brakes if they are dragging
Good shop for cleaning Mass air flow, fuel injector cleaning,?
