Results 1 to 10 of 10
- Oct 2013
- 2,537
April 6th, 2016 08:22 PM #1ano ba driving style mo at gusto mo mag palit ng brand? at ano ang purpose mo? racing racing ba o daily drive lang? ang purpose mo ba eh makatipid o yong pang racing racing na kakayanin ang matindi stress?
brake fluid? ganun din sa taas ang tanong ko sayo...
no experience sa power steering fluid, nung pinanganak ako electronic na ang steering
- Apr 2009
- 272
April 8th, 2016 06:07 AM #3
If you were using xw50 oil, then go to a xw30 oil. I think you might run into some leaking issue. I suggest go for a 10w40 semi synth. Shell helix hx7 i think is 300 per liter. You only need 4 liters. Havoline from caltex stations might be cheaper.
Any dot4 brake fluid. This is for your clutch also for the manual transmission.
Manual transmission oil will ask for API-GL4/5 75w90
Shell or Castrol should have these.
If automatic... dexron3 is the standard for the older transmissions. Shell Castrol
Also do a carburetor cleaning...
check sparkplugs...
clean air filters...
Check brake pads and drum brakes..
Lots of shops can do all of these under 3 hrs.
- Oct 2013
- 2,537
April 8th, 2016 10:08 AM #4i see, punta ka sa MIAS sa world trade center till weekend, PTT brand, P700 lang ang 5L 20w-50 API: SN mineral oil nila, libre pa ecobag pang bitbit ng binili mo oil, may free tshirt, oversized calendar, keychain at sticker pa... BFTB na sa akin yan...
brake fluid, any dot 3 would do, may schedule replacement duration naman yan
Are they on track to surpass last year's sales?
Car Sales Data (2025)
