ULTRON Race is the ultimate performance, synthetic engine oil designed to provide maximum engine protection for all passenger cars and light-duty trucks and vans powered by gasoline engines. ULTRON Race is suitable for high-performance engines, especially those fitted with turbochargers, or operated under the most severe conditions.
ULTRON Race is formulated using synthesized hydrocarbons and an advanced functional additive to provide outstanding thermal stability and oxidation resistance to prevent build-up of carbon and lacquer deposits on vital moving parts. Its 5W-40 viscosity grade allows ULTRON Race to flow faster through the engine providing supreme protection during cold-engine start-up when most engine wear occurs.
These features of ULTRON Race result in prolonged engine life and benefits unattainable by mineral oil-based and semi-synthetic based products.
Ultron Rallye is a multi-grade semi-synthetic engine oil designed to provide maximum engine protection for all passenger cars and light-duty trucks and vans powered by gasoline engines. ULTRON Rallye is suitable for high-performance engines, especially those fitted with turbochargers, or operated under the most severe conditions.
ULTRON Rallye is formulated using an advanced functional additive to provide outstanding thermal stability and oxidation resistance to prevent build-up of carbon and lacquer deposits on vital moving parts.
ULTRON Rallye contains a highly shear-stable polymer to provide control of viscosity throughout the life of the oil. It minimizes initial viscous drags providing fast start-up and rapid oil circulation from cold condition while maintaining adequate viscosity to protect against wear under fully warmed-up or high speed driving conditions.
The use of ULTRON Rallye results in reduced fuel consumption and extended oil drain intervals.
ULTRON Touring is Petron’s universal multi-grade gasoline engine oil designed to meet the high performance requirements of the most modern American, European and Japanese vehicles.
Properties:
- Gives superior anti-wear protection to cylinder rings, liners and valve
trains
- Keeps engine clean through superior control of sludge, rust, deposits,
gums and resins
ULTRON EXTRA is a multi-grade engine oil designed for gasoline engines used in moderate operating conditions such as passenger cars.
Properties:
- Provides anti-wear protection for cylinder rings, liners and valve trains
- Contains additives for better protection against sludge, varnish, rust,
wear and high temperature thickening
