Results 1 to 14 of 14
    Apr 2014
    Previously using Mobil Super 1000 15w40 and after that, Honda Vtec Lev 10w30 which are all Mineral Oil ...
    Engine was ok and noise is normal ..
    Change to Mobil Super 2000 10w40 Semi-Synthetic Oil .. Now the engine is very audible .. You can the valve tappets ticking ...
    Is it a normal noise of semi synthetic engine ?? Will it damage my engine in the long run ?? Or is it only Mobil because some say Caltex Havoline Semi Synthetic offers a silent engine ...
    Should I go back to Mineral Oil ???
    Car is Corolla .. Engine is 1.6 4afe ...
    Trying higher octane fuel.
    not oil related imo. time for tappet adjustment..
    Apr 2014
    Sabi nila hindi daw na-adjust ang valve tappets ng 4afe .. sa 2e lang daw yun ..
    Jul 2006
    Go back to using mineral oil. Try "thicker" oil this time, 20w50.
    Apr 2014
    Hindi naman knocking noise ang naririnig ko sir ... same fuel as before pa rin ginagamit ko .. mas audible lang ang noise ng valve tappets ngayon na nag semi-synth oil ako, dati sa mineral oil hindi naman ganito ka ingay ang tappets .. lalo nag pag operating temp na, tahimik na tahimik na ... pero ngayon sa semi synthetic oil, kahit operating temp na, dinig na dinig mo pa rin ang valve tappets noise kahit naka sarado ang hood ..
    Apr 2014
    sa mineral oil na mobil 15w40 at honda vtec lev 10w30, prehas naman sila tahimik ang makina ko ..
    nagka ganito lang ka ingay ang tappets after nag semi synthetic oil ako 2 weeks ago ..
    Jul 2006
    Synthetic oil has good detergent capabilities. Most probably, it loosened the "mineral" build-up on your valve train, hence the noise.
    Feb 2014
    don't fix if it ain't broken LOL i mean why change to fully synthetic anyway?
    funny i just saw my 90's corolla driving past earlier tonight, probably by it's 3rd owner. it's probably as old as your car. i never used fully synthetic on it
    btw when was the last time you checked the valve clearances? paano ba adjustment ng 4afe? shim based?
    Apr 2014
    Quote Originally Posted by Vodka View Post
    It's no fully synthetic .. its just a semi synthetic oil ..
    That's the problem .. all the mechanics and shop I've asked said there's no adjustments on 4afe's .. unlike the 2e engines that can be adjusted according to specs via shim ...
    Feb 2014
    Quote Originally Posted by Dezaremos View Post
    you sure? 2E valve clearance can be adjusted by turning the adjuster then tightening the locknut. i'm not sure about 4afe but if it's shim based then you have to find someone who knows how to change to the correct thickness shim
    Apr 2009
    Agree with this one. If its shim based, there is a thickness chart for the valve clearnace adjustment and usually done when the engine is cold. Casa and some autoshops have this. If your old shims are out of adjustment, its time to buy new shims..
    May 2011
    Since the abnormal noise started when the oil was changed,go with the last thing done. Stay away from the thought of changing the valve lifter shims. Believe me it's not fun specially shims are hard to find. On newer Toyotas it's even harder since you have to change the whole bucket valve lifter or cam follower.
    Jan 2008
    Same case sa tropa ko na naka tucson gas, umingay din nun gumamit sya ng mobil super 2000.
    Try mo paps havoline, un sa supervisor ko na jazz tumahimik nung gumamit sya ng havoline pro ds
    Sent from my R7plusf using Tapatalk
Noisy Ticking .. Is it noisy tappets ?? After oil change ..
