Results 1 to 5 of 5
- Feb 2009
- 102
June 10th, 2016 11:34 AM #1Hi po.
Car is Rav 4 2001 4X4 M/T.
Pag patag ang kalsada wala sya problema pero minsan bigla parang kinakapos kakadyot kadyot and bigla ok na uli. madalas pag paakayat na ang kalsada like mga fly over bigla nalang kinakapos na parang sinisinok at pakadyaot kadyot ang takbo.
Pinalitan nanamin mga spark-plugs at mga ignition coil. bukas papalinis ko yung gas tank.
Ano kaya posible na pwede ko pa pa check. bagong palit din clutch.
Thank you.
June 12th, 2016 11:37 PM #4
is the condition more pronounced or prevalent when the fuel tank level is low?
is the condition non existent when the tank is full?
- Feb 2009
- 102
June 13th, 2016 12:19 PM #5Thank you mga sir sa reply. regarding fuel level sir parehas lang kahit puno or malapin na sa empty.
update: hindi dumating yung mekaniko na mag lilinis ng fuel line. sinunod ko muna yung sinabi dun sa ibang trend na "drive it like you stole it" hataw ako sa sky way sagad up to 6,000 yung rpm up to 4th gear lang. nawala yung sinok at kadyot. up to tagaytay. pero nung pabalik na ng manila bumalik uli yung sinok pero konti nalang.
That makes sense. Higher elevation has lower atmospheric pressure and even if the cooling system is...
