Results 1 to 5 of 5
- Oct 2009
- 179
September 5th, 2013 11:15 PM #1Help, when pressing brake pedal nararamdaman ko parang mamatay ang makina. Sa hose kaya ito ng brake booster or sa brake booster itself? Mataas din pala idle ng sasakyan, pag bukas 900rpm then pag mainit na 1.5k rpm. Delayed acceleration and lose of power but definitely not sliding. Carb type engine.
Follow up question po, wala na pala nakakabit na hose sa advance ng distributor kailangan ba meron? How can i test the advance mechanism if it is still working? Kakakuha ko pa lang ng sasakyan. Nissan sampaloc engine.
Thanks.
- Mar 2013
- 24
September 6th, 2013 08:23 PM #2mataas masyado idle mo.. normal idle pag mainit na makina is around 7 to 8 rpm then 9 to 1000 pag naka aircon... pag cold start around 1500 then baba sya sa a little below normal pag medjo uminit na.. then normal pag mainit na...
- Oct 2009
- 179
- Jul 2010
- 570
September 10th, 2013 08:57 AM #5
They're hell-bent on sustainability kasi... even at the expense of a shorter lifespan from their...
BYD Philippines
