Results 1 to 10 of 18
- May 2005
- 215
May 24th, 2005 03:26 PM #1Does anybody know where I can get a "drop in" type K&N filter for a 2004 2.0L accord? and some follow up questions;
1. K&N filters are suppose to add more air going into the manifold for better performance correct? with more air going in, will it result in lean burn?
2. Assuming there is lean burn, will the electronics of the accord readjust its a/f ratio to compensate, therefore negating the purpose of the filter?
Thanks for your opinions.
May 24th, 2005 03:40 PM #2
more air will cause the ECU to use more fuel. the ECU will compensate kaya mas tataas HP mo, well thats what they claim. i only know of the HKS drop in filter which will cost maybe 4k
- May 2005
- 215
May 24th, 2005 03:51 PM #3Originally Posted by BlueBimmer
May 24th, 2005 03:52 PM #4Originally Posted by kuyapete
BTW, a drop-in filter will not noticably increase your engine's performance. For that, you'll need a cone-type open-element filter.
- May 2005
- 215
May 24th, 2005 04:02 PM #5Originally Posted by ghosthunter
May 24th, 2005 04:06 PM #6Originally Posted by kuyapete
May 24th, 2005 04:07 PM #7Originally Posted by kuyapete
as for floods, it will only be dangerous if the flood water level reaches the filter & your hood would surely be submerged also. in which case you shouldn't be doing in the first place.
- May 2005
- 215
May 24th, 2005 04:22 PM #8Originally Posted by mazdamazda
May 24th, 2005 04:43 PM #9Originally Posted by kuyapete
K&N Cone filters typically cost about P3.5K up.
- May 2005
- 215
May 24th, 2005 06:03 PM #10Originally Posted by ghosthunter
Babala! Sarado at Ginagawa mga south bound flyovers along c5. Medyo mabagal Ang daloy kanina Ng...
Traffic!
