Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Apr 2014
    If your car's owner's manual say the recommended viscosity is
    10w30 or 10w40 ..
    What happens if you use 5w30 or 5w40 ??
    Is 5w30 too thin for a 20 yr old car ?? Corolla GLi 4afe ..
    Currently using Mobil 10w40 ... Last year was using vTec LEV 10w30 ..
    Jan 2009
    You should be ok with a 5W or 10W40 oil.
    and even with a 0w40
    Apr 2014
    I wanted to try a 5w30 kasi .. Will it be ok with my engine ??
    Jun 2015
    Quote Originally Posted by Dezaremos View Post
    If 10w30 is in your owner's manual then 5w30 or 0w30 is also ok. What's important is the "30".
    Jan 2009
    Personally... and it's just my opinion... a 20 y/o vehicle will probably be better off with a 5W-xx or 10W-xx. Reason being, the engine might actually benefit from a relatively thicker oil at cold start because part tolerances have presumably loosened up enough that an 0W oil may no longer provide enough initial protection.
    Note also that motor oil takes a lot more time to warm up and reach the target viscosity. By comparison, the coolant temperature warms up significantly faster thanks to the thermostat valve, which can reach operating temp in about 5 minutes. Motor oil, however, could take anywhere around 15-20 minutes to reach normal operating temp. In other words, the oil might stay in the lower end of the viscosity range far longer than necessary.
    Anyway, I'm just splitting hairs.
    very similar to the 10w30 honda oil you used. don't worry much...
    hardly any difference at 40C for 5w30 and 0w40, 72.8 and 75 cSt respectively
    Mobil 1 New Life™ 0W-40
    Mobil 1™ ESP Formula 5W-30
    Apr 2014
    Don't have the manual when I bought it 2nd hand .. But I googled the 4afe engines used in Corollas abroad and it stated that the recommended viscosity is 10w30 or 10w40 ...
    But those viscosities are from other countries, I don't know if its applicable here in the philippines tropical climate ...
    Unlike your Honda, it is really widely known that 10w30 is the recommended oil viscosity ...
Oil Viscosity not in the manual ...
