Results 1 to 4 of 4
- Jun 2005
- 3,774
December 27th, 2010 01:58 AM #1hello! would anyone know the engine code of a 2006 ford focus 1.6 gas engine? Im looking for a surplus tps sensor kasi and easiest way to look for 1 kapag engine code sabihin.
may nagsabi same daw with mazda3 ito? Ibebenta na kasi yung car but will need to get it moving first. already tried to have the TB cleaned umayos saglit pero nag check engine uli. sensor na daw yun eh
December 27th, 2010 08:42 AM #2
pa scan mo muna para malaman ang trouble code; use Pxxxx format, i'm sure marami makakatulong sa iyo kung malalaman ang exact DTC.
- Jun 2005
- 3,774
December 28th, 2010 08:16 PM #3P0123 ang code. ayos na at nakabili na ng surplus tps. ok na uli yung focus
December 28th, 2010 08:32 PM #4
A bit late pero an '06 Focus:
1.6L - Z6 engine
1.8 / 2.0L - Duratec engine
1.6 / 2.0L - Duratorq-TDCi engine
1.8L - Duratorq-TDCi engine
And P0123 is just that - Throttle Position Sensor / Switch A Circuit High Input
high idle RPM at engine start
