Results 1 to 7 of 7
- 17
November 11th, 2002 09:48 PM #1Ano ba problema pag hard starting sa umaga ang sasakyan? pero pagstart tuloy tuloy naman. Lalo na kung malamig panahon. Injection o makina?
November 11th, 2002 10:45 PM #2
check that all your glowplugs are in working order. Bunutin isa isa and recta sa battery. The tip should smoke after a second. pag hindi nag smoulder, malamang defective.
hope this helps... goodluck!
November 12th, 2002 12:41 AM #3
Yep, that's the first thing you check, yung glow plugs. Ano na odometer reading mo?
If they are defective, make sure you change all of them, huwag yung isa-isa...
Kakapalit ko lang kasi yesterday. Same problem na medyo weird ang pag-start sa umaga..
November 12th, 2002 11:41 PM #6
Bakit kaya yung MB100 namin ang lakas sumira ng glow plugs? Mukhang sira na naman. Hay...
November 13th, 2002 12:49 PM #7
otep::: Di kaya theres something wrong with the relay which feeds the plugs. Baka longer than intended yung bigay ng kuryente?
Suzuki JIMNY [merged threads]
